주요 콘텐츠로 건너뛰기
Irulu walknbook Windows 10 tablet battery Replacement
필요한 것
  1. Irulu walknbook Windows 10 tablet  battery Replacement, battery: 1 단계, 이미지 1개 중 1개
    • this is what you should end up like with the tab
  2. Irulu walknbook Windows 10 tablet  battery Replacement: 2 단계, 이미지 1개 중 1개
    • first remove the orange (or other colour) bezels from the side of the tab. the all have a small hole grip.
  3. Irulu walknbook Windows 10 tablet  battery Replacement: 3 단계, 이미지 1개 중 1개
    • on the back cover there is a glass cover that covers up the screws. be carefull when removing it because it might break. use small like credit cards to seperate it but still be very carefull.
  4. Irulu walknbook Windows 10 tablet  battery Replacement: 4 단계, 이미지 1개 중 1개
    • so the back cover seperates in to two parts. after removing the glass part the screws are visible. remove all of them. the back cover can pe removed very easily.
  5. Irulu walknbook Windows 10 tablet  battery Replacement: 5 단계, 이미지 1개 중 1개
    • you then end up with all the rest of the internal parts visible. now you can replace the battery or the display. there is also a 3g port slot but i haven't tried it out yet. let me know if this worked for you.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Dili
회원 가입일: 08/29/15
242 평판
안내서 1개를 작성함
11가이드 댓글
Hey I have another question is it possible to replace the ram in it or no
jackroc21 - 답글
No that is not possible because the ram is soldered on the main board.
Dili -
where can I buy a replacement battery for this walknbook????
hushpuppy43 - 답글
Donde puedo comprar la batería ,no la encuentro.
will5551970 - 답글
Necesito comprar la batería para la irulu
Battery:7800 mAh irulu w1002
Donde la venden.
will5551970 - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 36
전체 시간: 6,152
