주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Itel 2163 Disassembly
필요한 것
  1. Itel 2163 Disassembly, Switch off the phone: 1 단계, 이미지 2개 중 1개 Itel 2163 Disassembly, Switch off the phone: 1 단계, 이미지 2개 중 2개
    • First switch off the phone by longpressing the power button.
  2. Itel 2163 Disassembly, Remove Back Cover and Battery: 2 단계, 이미지 3개 중 1개 Itel 2163 Disassembly, Remove Back Cover and Battery: 2 단계, 이미지 3개 중 2개 Itel 2163 Disassembly, Remove Back Cover and Battery: 2 단계, 이미지 3개 중 3개
    • Remove the back cover of the phone and the battery, then check for any available sim card(s), and eject the sim card(s) from the sim bed(s).
  3. Itel 2163 Disassembly, Unscrew the Nuts: 3 단계, 이미지 3개 중 1개 Itel 2163 Disassembly, Unscrew the Nuts: 3 단계, 이미지 3개 중 2개 Itel 2163 Disassembly, Unscrew the Nuts: 3 단계, 이미지 3개 중 3개
    • Get the phillips #00 screwdriver and check for the available four (4) nuts/screws attaching the front and middle case together.
  4. Itel 2163 Disassembly, Pry the Phone open: 4 단계, 이미지 3개 중 1개 Itel 2163 Disassembly, Pry the Phone open: 4 단계, 이미지 3개 중 2개 Itel 2163 Disassembly, Pry the Phone open: 4 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Get a plastic card and slice open the phone at the rear end towards the charging port in order to separate the middle case (sim bed case) from the front case (screen case).
    • Do not pry the phone open with your finger, it is not safe and ethical as you can injure your finger nail in the process.
  5. Itel 2163 Disassembly, The Motherboard in view: 5 단계, 이미지 3개 중 1개 Itel 2163 Disassembly, The Motherboard in view: 5 단계, 이미지 3개 중 2개 Itel 2163 Disassembly, The Motherboard in view: 5 단계, 이미지 3개 중 3개
    • After prying the phone open, you will then be left with the motherboard and screen in view. Attached to the motherboard, you'll see the charging port, the mic, the speaker, the earphone jack, etc.
    • Be careful with handling of the screen so as not to cause any defect to the screen flex thereby making the screen to malfunction or not work again.
결론
To reassemble this device, follow these instructions in reverse order.
다른 18명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Aanuoluwapo Owoseeni
회원 가입일: 04/28/22
725 평판
안내서 1개를 작성함
2가이드 댓글
when i talk to sombody my voice is not clear
bhanu chandar - 답글
Would the screen be usable if remove it from the motherboard?
Ishita Gupta - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 24
지난 30일: 130
전체 시간: 3,612
