주요 콘텐츠로 건너뛰기
Ivation IVWPDC20Y Lens Assembly Replacement
필요한 것
  1. Ivation IVWPDC20Y Lens Assembly Replacement, Lens Assembly: 1 단계, 이미지 1/1
    • With the H2.0 bit screwdriver, remove the two screws on the yellow waterproof cover
  2. Ivation IVWPDC20Y Lens Assembly Replacement: 2 단계, 이미지 1/1
    • Apply a plastic opening tool to each of the corners and gently remove the casing
    • The front casing is held down by adhesive and may require additional work to remove
    • Apply just enough force to undo the inner latches to make sure not to damage the waterproof seal
  3. Ivation IVWPDC20Y Lens Assembly Replacement: 3 단계, 이미지 1/1
    • Remove the five silver screws from the inner casing using the PH00 screwdriver bit
  4. Ivation IVWPDC20Y Lens Assembly Replacement: 4 단계, 이미지 1/1
    • Remove the six screws from the edge of the clear inner casing with the PH00 screwdriver bit
    • These screws are very small and easy to strip so apply consistent pressure when removing them
  5. Ivation IVWPDC20Y Lens Assembly Replacement: 5 단계, 이미지 1/1
    • Pry off back outer casing using the black spudger or the blue prying tools
  6. Ivation IVWPDC20Y Lens Assembly Replacement: 6 단계, 이미지 1/1
    • Carefully remove the screen from the silver casing using a prying tool or the black spudger
    • There is adhesive in the center of the screen, be sure not to bend it when applying pressure
  7. Ivation IVWPDC20Y Lens Assembly Replacement: 7 단계, 이미지 1/1
    • Using the poker end of the spudger push gently on the black pegs holding the orange tape in place
    • Screen and orange tape should slip out as a whole
  8. Ivation IVWPDC20Y Lens Assembly Replacement: 8 단계, 이미지 1/1
    • Remove three screws holding the silver screen casing to the motherboard using the PH00 bit screwdriver
  9. Ivation IVWPDC20Y Lens Assembly Replacement: 9 단계, 이미지 1/1
    • Remove three screws holding the motherboard into the casing using the PH00 bit screwdriver
  10. Ivation IVWPDC20Y Lens Assembly Replacement: 10 단계, 이미지 1/1
    • Gently lift the corner of the motherboard out
    • Everything should come out as one component free of the casing
  11. Ivation IVWPDC20Y Lens Assembly Replacement: 11 단계, 이미지 1/1
    • Remove the two screws holding the lens assembly to the motherboard using the PH00 bit screwdriver
  12. Ivation IVWPDC20Y Lens Assembly Replacement: 12 단계, 이미지 1/1
    • Remove the soldering on the 3 wires that are connected to the lens unit
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Jack Schlandt
회원 가입일: 02/08/16
197 평판
안내서 1개 작성함
USF Tampa, Team 6-6, Eyestone Spring 2016 USF Tampa, Team 6-6, Eyestone Spring 2016 회원
USFT-EYESTONE-S16S6G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 4
전체 시간: 277
