주요 콘텐츠로 건너뛰기
JBL Charge 2+ Speaker Replacement
필요한 것
  1. JBL Charge 2+ Speaker Replacement, Uncovering the Speakers: 1 단계, 이미지 3개 중 1개 JBL Charge 2+ Speaker Replacement, Uncovering the Speakers: 1 단계, 이미지 3개 중 2개 JBL Charge 2+ Speaker Replacement, Uncovering the Speakers: 1 단계, 이미지 3개 중 3개
    • Remove the metal grill: starting from bottom-left corner, use a guitar pick or spudger to lift the metal grill.
    • *Pro-tip* if it feels like it's not moving, just be patient and do not try to use more force: apply a gentle continuous pressure and it will slowly starting coming off. Be patient.
    • Unscrew the four screws that hold each speaker in place (8 total).
  2. JBL Charge 2+ Speaker Replacement, remove: 2 단계, 이미지 3개 중 1개 JBL Charge 2+ Speaker Replacement, remove: 2 단계, 이미지 3개 중 2개 JBL Charge 2+ Speaker Replacement, remove: 2 단계, 이미지 3개 중 3개
    • Slide each of the quick cables from the speaker off.
    • Replace the speakers : simple reinstall in reverse order.
    • To reinstall the metal grille: gently and firmly line it up and press into place. If needed, use the spudging tool to guide the last corners into place.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
John Reynolds
회원 가입일: 10/16/15
3,298 평판
안내서 4개를 작성함
UMass Dartmouth, Team 4-1, Catania Fall 2015 UMass Dartmouth, Team 4-1, Catania Fall 2015 회원
UMASSD-CATANIA-F15S4G1
4 회원들
안내서 14개를 작성함
11가이드 댓글
How did you remove the IRON NET ?
Olivier - 답글
http://bit.ly/1VlVWXH - First step in this guide. Hope this helps :)
Tapiwa -
hello
where can i find this speaker replacement?
amati - 답글
I believe I blew my speakers, where/how can I purchase replacement speakers?
Francisco Garcia - 답글
Where to buy these speakers online?
aurimasslepikas - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 16
지난 30일: 94
전체 시간: 29,741
