주요 콘텐츠로 건너뛰기
JBL Charge 2 Battery Replacement
필요한 것
  1. JBL Charge 2 Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the screen cover from the speaker using a metal spudger.
  2. JBL Charge 2 Battery Replacement: 2 단계, 이미지 1/2 JBL Charge 2 Battery Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver (PH1), remove the (4) four 8mm screws.
    • Remove the end cap of the device. Repeat the same process to remove the other end cap.
  3. JBL Charge 2 Battery Replacement: 3 단계, 이미지 1/2 JBL Charge 2 Battery Replacement: 3 단계, 이미지 2/2
    • To remove the end diaphragms, use a Phillips #1 screwdriver (PH1) and remove the (4) four 6mm screws.
    • Twist off the end cap and remove them from the device.
  4. JBL Charge 2 Battery Replacement: 4 단계, 이미지 1/2 JBL Charge 2 Battery Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver (PH1) to remove the (2) two screws from the battery cover.
    • Pry away the plastic battery cover with a plastic spudger.
  5. JBL Charge 2 Battery Replacement: 5 단계, 이미지 1/1
    • Disconnect the battery connector with a plastic opening tool and wiggle the connector free.
  6. JBL Charge 2 Battery Replacement: 6 단계, 이미지 1/3 JBL Charge 2 Battery Replacement: 6 단계, 이미지 2/3 JBL Charge 2 Battery Replacement: 6 단계, 이미지 3/3
    • Scrape the battery wire sealant off with a plastic opening tool, and ensure it is free of the body of the speaker and wires.
    • Slide the battery free.
결론
다른 10명이 해당 안내서를 완성하였습니다.
Mauzor Ilonzo
회원 가입일: 09/26/17
495 평판
안내서 3개 작성하였습니다
USF Tampa, Team S2-G4, Passmore Fall 2017 USF Tampa, Team S2-G4, Passmore Fall 2017 회원
USFT-PASSMORE-F17S2G4
4 회원들
안내서 8개 작성하였습니다
댓글 3개
Thanks for the manual! Easy repair this way.
Jeroen Cox - 답글
The JBL Charge 2 I have only needs the rear screen to be taken off. Once removed, just unscrew the battery holder plate. No need to unscrew the bass speakers. The battery plate is pretty well protected against water entering. You have to remove some silicone caulking to take out the power plug. My speaker takes the “New” Charge 2 battery.
Rogelio Fernandez - 답글
Could you please suggest me where to buy battery for JBL Charge 2. Iam from Visakhapatnam, India. My mail vasudev.chiratla@gmail.com.
Vasudev Chiratla -
댓글 쓰기
조회 통계:
24 시간 전: 11
7일 전: 69
30일 전: 287
전체 시간: 20,170
