소개
On ne démontera pas l'enceinte à 100%, juste les plus gros morceaux.
Cette enceinte a été bricolée au niveau de port de charge (installation d'un neuf).
필요한 것
동영상 개요
Utilisez une spatule en plastique ou une carte de crédit pour ouvrir les grilles
Vous devriez pas avoir à exercer trop de force sur les grilles. Il y a un petit peu de colle dessus.
Enlevez les 4 premières vis
Faites sauter le rond de plastique puis occupez-vous des 4 vis restantes.
Vous pouvez maintenant accéder à la carte mère
Pour déconnecter la batterie, déconnectez d'abord le micro pour vous faciliter la tâche
Dévissez les deux vis du cache blanc
Sortez le de son encoche, et voilà la batterie !
Nice tutorial on how to dismantle the device, but what if I want to separate out the power bank part of this device and dump the rest due to worn out speakers. Is it possible to do that? If not, will it still work as a power bank if I simply the wires to the speakers and remove them. I’d rather remove the amplifier as well so that unnecessary power consumption is reduced.
Pour réassembler votre appareil, suivez les instructions dans l'ordre inverse.
다른 10명이 해당 안내서를 완성하였습니다.
댓글 13개
About to try this, will give feedback
This is the charge2 + not the charge2
The Daniel - 답글
there aren,t any screws in the cap
I have the same problem. I think this is a TL model, but I have not been able to find any information on how to correctly remove the end caps. I don’t want to scratch or break anything trying to pop the end caps off.
Bobcov -
Thanks so much! I had a broken bit of plastic inside the tube after I left my speaker in my checked luggage and it got smashed around. I followed the instructions and managed to get it out, the speaker is purring again without the annoying ass rattle!! You're a legend my friend. TY
itgotfixed - 답글
You are welcome !
Hello, I have a problem
I lost the speaker screws
can you tell me what type of screws I have to buy?
thank you in advance
Bobo amputaa
Ce tuto ne concerne PAS le charge 2, mais bien le charge 2+
Le principe d’ouverture est bien différent !
So easy steps to follow. Thank you so much. The guide is really helpful.
It came handy when my boss complained about a fault, so I tried figuring it out, then I googled steps to dismantle, and pop! The video showed up. Really helpful. Thanks
omo4rmzion - 답글
This tutorial really helped :)
JITHIN ROY - 답글
Bonjour à tous, je constate que sur ce tuto on a des personnes qui gèrent donc bcp d'amitié
et de remerciement à tous vous êtes tjrs en mode cool et ça fait vraiment merci et n'hésitez pas à me demander un service
je serai fier de vous rendre service et encore merci Thameur
comme vous l'avez sans doute compris "bcp plaisir"
