이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
This guide goes over how to remove the battery from the JBL Charge 2+.
필요한 것
Starting from the front side bottom left corner, use the nylon or metal spudger to lift the grille up from each of the four corners.
Follow the previous instruction to remove the back grille.
Remove the battery wire from the circuit board by pulling it out gently on the side closest to the LCD light.
다른 72명이 해당 안내서를 완성하였습니다.
댓글 37개
Had my speaker for a month. It won't charge. Why did it only last a month and I have to get a new one? I'm not satisfied with the speaker for the price that I paid.
When I charge my jbl the light in tge power button turns on but when I press it the device does not respond. Please help me...
Try disconnecting the battery and plugging it in again.
I just had the same problem, the on/off led got stuck and couldn't get any sound or operation from any button. After different attempts a simultaneous pressing of the Phone together with the - and the + button brought my Charge2 to life again.
