주요 콘텐츠로 건너뛰기
JBL Charge 2 Plus Bottom USB Ports and Aux Port Replacement
필요한 것
  1. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement, Bottom usb ports and  aux port: 1 단계, 이미지 1/1
    • Flip the device so the bottom is facing you.
    • Remove the bottom pad with a nylon or metal spudger.
  2. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: 2 단계, 이미지 1/2 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: 2 단계, 이미지 2/2
    • Remove the 4 screws that hold the white cover.
  3. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: 3 단계, 이미지 1/1
    • Slide under the cover and remove it.
  4. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: 4 단계, 이미지 1/2 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: 4 단계, 이미지 2/2
    • Remove the one screw holding the circuit board.
  5. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: 5 단계, 이미지 1/1
    • Pry the board with the plastic opening tool.
  6. JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: 6 단계, 이미지 1/2 JBL Charge 2 Plus Bottom USB Ports and  Aux Port Replacement: 6 단계, 이미지 2/2
    • Slide the ribbon gently out of the connector.
결론
다른 15명이 해당 안내서를 완성하였습니다.
John Reynolds
회원 가입일: 10/16/15
3,006 평판
안내서 4개 작성하였습니다
UMass Dartmouth, Team 4-1, Catania Fall 2015 UMass Dartmouth, Team 4-1, Catania Fall 2015 회원
UMASSD-CATANIA-F15S4G1
4 회원들
안내서 12개 작성하였습니다
14 댓글
Hi! I need the mini usb piece but I don´t know were I can buy it, it is not like the mobile one´s! Please help me!
Thanks
Clash Ofclans - 답글
Just having the same issue with the internally broken micro-usb connector. Is it standard, or something special? Thanks!
egyusza - 답글
I think it is not normal, if you can find it please contact me! Thanks
Clash Ofclans - 답글
I also need to replace my usb connector, has anyone found out where to get one?
Rick - 답글
need the micro-usb aswell
hellgrenmicke - 답글
댓글 쓰기
조회 통계:
24 시간 전: 8
7일 전: 36
30일 전: 121
전체 시간: 25,588
