소개
This guide can be used to replace your USB ports and aux cable.
필요한 것
Flip the device so the bottom is facing you.
Remove the bottom pad with a nylon or metal spudger.
Slide the ribbon gently out of the connector.
What the name of the white ribbon and where can i buy another mine on my jbl got damaged
Jose Lopez - 답글
From where can I get the micro usb port. Its broken…or what's its called?
다른 17명이 해당 안내서를 완성하였습니다.
댓글 15개
Hi! I need the mini usb piece but I don´t know were I can buy it, it is not like the mobile one´s! Please help me!
Thanks
I think it is not normal, if you can find it please contact me! Thanks
need the micro-usb aswell
My jbl charge 2+ is different, after removing the plastic thing in step one there aren't any screws
[|same too at mine :-(]
Eki mako -
I tried step one and was only able to peel off the rubber base exposing the double sided tape. I do not see the cover as shown in step 2. Any help is greatly appreciated. Thanks!
Same case here… :-(
Eki mako -
Buy online 100% fit http://bit.ly/2wxk2GC
How can i make the sound come back?
where do i get the part?!?!? Torn down the speaker allrdy..
The easiest thing is to replace the whole circuit board, I’d try ebay and get something like this https://www.ebay.com/itm/JBL-CHARGE-2-SP...
fdsajky675 - 답글
Has anyone tried to install a USB-C in a JBL Charge 2+?
