주요 콘텐츠로 건너뛰기
JBL Charge 2 Speakers Replacement
필요한 것
  1. JBL Charge 2 Speakers Replacement, Battery: 1 단계, 이미지 1/1
    • Remove the screen cover from the speaker using a metal spudger.
  2. JBL Charge 2 Speakers Replacement: 2 단계, 이미지 1/2 JBL Charge 2 Speakers Replacement: 2 단계, 이미지 2/2
    • Using a Phillips #1 screwdriver (PH1), remove the (4) four 8mm screws.
    • Remove the end cap of the device. Repeat the same process to remove the other end cap.
  3. JBL Charge 2 Speakers Replacement: 3 단계, 이미지 1/2 JBL Charge 2 Speakers Replacement: 3 단계, 이미지 2/2
    • To remove the end diaphragms, use a Phillips #1 screwdriver (PH1) and remove the (4) four 6mm screws.
    • Twist off the end cap and remove them from the device.
  4. JBL Charge 2 Speakers Replacement: 4 단계, 이미지 1/2 JBL Charge 2 Speakers Replacement: 4 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver (PH1) to remove the (2) two screws from the battery cover.
    • Pry away the plastic battery cover with a plastic spudger.
  5. JBL Charge 2 Speakers Replacement: 5 단계, 이미지 1/1
    • Disconnect the battery connector with a plastic opening tool and wiggle the connector free.
  6. JBL Charge 2 Speakers Replacement: 6 단계, 이미지 1/3 JBL Charge 2 Speakers Replacement: 6 단계, 이미지 2/3 JBL Charge 2 Speakers Replacement: 6 단계, 이미지 3/3
    • Scrape the battery wire sealant off with a plastic opening tool, and ensure it is free of the body of the speaker and wires.
    • Slide the battery free.
  7. JBL Charge 2 Speakers Replacement, Speakers: 7 단계, 이미지 1/1
    • Remove the opposite screen cover using a metal spudger
  8. JBL Charge 2 Speakers Replacement: 8 단계, 이미지 1/1
    • Use the Phillips #1 screwdriver (PH1) to remove the (8) eight screws.
    • Pull out the speakers from the device.
  9. JBL Charge 2 Speakers Replacement: 9 단계, 이미지 1/1
    • Disconnect the wiring from the speaker by using the fine tip pry tool.
    • Remove the speakers from the device.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Mauzor Ilonzo
회원 가입일: 09/26/17
495 평판
안내서 3개 작성하였습니다
USF Tampa, Team S2-G4, Passmore Fall 2017 USF Tampa, Team S2-G4, Passmore Fall 2017 회원
USFT-PASSMORE-F17S2G4
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 7
30일 전: 49
전체 시간: 4,643
