소개
Your battery may need to be replaced if it doesn't hold a charge or is not charging at all. The JBL Charge 3 has a 6000mAH battery.
필요한 것
Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
Repeat this process for all four edges of the front cover.
Pull apart your cover gently from both sides and remove it from the speaker housing.
@KanGoon Yes, on mine it took the removal of 6 (reasonably obvious) screws to remove that. I’ll try to insert a photo when I reassemble…
Very good guide! Pics and descriptions make this easy!
There is a step missing here. How do you remove the rubber cover that covers the port?
Gibt es eine Möglichkeit diese wieder wasserdicht zu bekommen?
Remove the two 8mm Phillips #1 screws from the tabs.
NOTE: There may be only one screw.
If your Charge 3 doesn’t look like the above. Do not do this step YET. Go directly to Step 7 removal of the battery. By doing the battery first it will tell you which radiator to remove and thus no need to remove both.
NOTE:
On a newer version of the Charge 3 this image will be very different. you will not find a screw. You will also notice that there are two tabs that if slightly lifted while rotating the radiator counter clockwise the radiator is easily removed. There is also no foam or breakable seal on the newer Charge 3.
Insert the plastic opening tools underneath both tabs.
I believe this is unnecessary, just turn the passive radiator counter clockwise and pull outward. I tried to use the pry tool and broke a plastic tab.
Tip— when you get to this part lightly tap the edge of the speaker on a hard surface— like you’re tapping a jar before opening it.
Muchas gracias a todos, me dieron cada uno la guía perfecta.
My charge 3 had less screws but the process was the same. Thanks for the instructions!
Twist and pull open the passive radiator. The left radiator twists off clockwise; the right counterclockwise.
Repeat all previous steps for the other passive radiator.
NOTE: only the right radiator needs to be removed for changing the battery.
right or left…. depends on how you view the Charge 3 i guess. No need to remove both radiators for a newer Charge 3. You can remove the battery cover first…find out what side the battery wires exit the battery compartment and then remove the radiator associated with that same side.
Anybody else have major problems trying to twist the radiator back into position after replacing the battery? I’m having trouble getting the screw holes to line up again on the right radiator.
To twist back I used saliva so it will slide easier against the rubber
Remove the six 8mm Phillips #1 screws from the outer battery cover.
Peel the outer battery cover away from the speaker housing.
For the newer Charge 3 - there are two silver screws located on the opposite side of the charging ports ….. looking at the first picture above they would be in close proximity to the lower two red circles. However, they placed in horizontally not vertically. Once you remove these two screws you can lift the rubber off.
Note: The rubber is hinged on the opposite side of the two removed screws by tabs. Be careful when rotating it off not to break the tabs.
Once the rubber is removed…. you will be able to see the battery compartment. It has several black screws… one of which is wedged between the charging port rubber and the battery cover. You can gently pry up the rubber away to allow you to get a screw driver in to get the middle screw out.
The battery compartment is water tight and has a seal. You will want to loosen all screws evenly so as not to tear or damage the rubber seal.
Remove the seven 8mm Phillips #1 screws from interior battery cover.
Remove the interior battery cover.
The newer Charge 3 will have a solid black cover. Once removed the battery can be easily lifted out with your fingers. It is not taped in.
Gently lift the battery to determine the radiator that needs to be removed. You can identify it by following the battery wiring. There is a small hole at the bottom of the battery compartment that the battery wires go through. The side with the battery wiring hole is the same side as the radiator that needs to be removed.
Pull gently to disconnect the bundled cable connector in the side of the speaker. This action will separate the battery from the motherboard.
mon problème d’origine était pas de charge sur secteur, dans mon cas nappe 11 connecteurs déconnectée. Je n’ai pas vu de système de retient pour cette nappe, je lui ai ajouté un petit point de colle, car bouge relativement beaucoup ! problème résolu
Pull the battery and battery cable out from their housing.
yo tambien quiero una bateria donde la cosigo?
Does anyone know where I can buy a replacement battery?
Unbedingt die Isolierung um das Kabel und die Polster an den Ecken der Batterie von der alten an die neue basteln, sonst kann sie im Fach hin und her klappern.
Se podria adactar este dispositivo directo a un cargador directo?
I already did many things to my charge 3 and one of them was to put two direct cables to the battery to be able to charge it since the usb port was damaged and I could not find a replacement, next I will add 4 more batteries
perdon que te respondi en ingles, yo le puse un cable directo usb a la bateria ya que el puerto usb se daño y no pude encontrar repuestos
다른 132명이 해당 안내서를 완성하였습니다.
댓글 32개
you legend. thank you so much! i was worried it was a seal unit!
Super Anleitung! Hat der Akkutausch hat problemlos funktioniert!
Great Guide! Where can I get the foamy coating of the battery’s wires? Or what is the proper term?
I saw one on youtube taking the one from the old battery and putting it on the new one
Replacement Battery for JBL Charge 3 Part NO GSP1029102A https://www.amazon.com/dp/B07NK8NFR4/ref...
I used two credit card instead od the plastic opening tool, they work great. Thanks for the help!!!
I did this and now I get a red blinking light when trying to charge it. No idea how to fix it.
Wow thank you! Very clear instructions, easy repair. So happy to have my stereo back!
My old battery was so swollen, i wonder what caused that?
Dan Warden - 답글
Thank you for this guide! It wasn’t exactly the same as my Charge3, but close enough. The original battery (once I got to it) was swelling and had broken some of the plastic tabs around the screws. Ugh. Good thing I found this guide and the battery purchased through iFixit. Thanks again!
For the love of God, don’t try to follow these instructions. They are worse than useless. I wasted 2 hours and over $60 between the battery and new screwdrivers and the end result is that I can’t even get the battery open to change it. Also, when I tried to put the cover back on the tab broke off so now my speaker is completely useless. (Prior to attempting to fix it, it still worked great when it was plugged in). I would have been better off just buying a new speaker for a little more than 2x the cost of the battery, considering that now I’m going to have to do that anyway. Thanks for absolutely nothing (except scamming people into buying replacement batteries from you).
Thank you for the instructions nailed
Good guide. Not a great guide, but a good guide. When you use this in conjunction with more detailed resources it works very well. I couldn’t find any one guide that gave all the details, but found many which provided enough different details to piece it together. This guide made for a very clear outline of the process.
Do you provide an alternative to instead of replacing the battery. We just replace its powersource?. The battery is 1/3rd the price of the unit already. Replacing the powersource from a micro usb port should do the trick to using it long term without spending 40-50 bucks every 12-18 months just to replace the battery.
This is a JBL Charge 3? It looks nothing, in the inside, like the one I have, and the battery is just a small cylinder, nothing like what you've shown above. There are only 2 tabs for the front cover, the other two are screwed in. And there are 8 small screws to completely disassemble the unit, this is so odd! Well, thank you, at least i was able to open it, but the cylindrical battery appears to be hardwire.
Monica Tew - 답글
A great guide, thank you.
With steps 4,5 and 6, I had a much better time lifting the tabs by putting the thin plastic spudgers between the tabs, instead of using the plastic opening tools.
New battery in, didn’t charge either… Probably something wrong with the charging circuit, too bad.
Either way, good step by step manual, managed to open it en seal it up again properly!
bonjour, mon problème d’origine était pas de charge sur secteur.En cause la grosse nappe déconectée. Merci Ifixit pour ce tuto qui m’a bien orienté !
awesome guide, could replace it quick. thank you very much
Lukas Tram - 답글
Good Guide mate, I just replaced my Charge 3+ which is a bit different from the original but aside from having 2 screws holding the last part of woven cover, the right radiator “now” has two pull tabs that you slide the picks in and just rotate the radiator base. Other than that seems pretty similar and/or intuitive. There’s a few videos on youtube opening the charge 3+ in case someone needs a visual hand.
Très content de ce tutoriel qui m' a permis de changer la batterie de ma Charge 3 facilement et de pouvoir continuer à m'en servir. Merci !
My jbl charge3 speaker will turn on, but will immediately turn off & when charging will blink at the first of the 5 charging indicators...how can this be repaired?
can i get a new battery cover .my battery has swollen and destroyed all the screw mounts?
You’re the best!!
Top, kurz und knapp fix den Akku getauscht,trotz Handicap
All perfect thank you guys fot the amazing job
Buen dia, mi JBL Charge 3 no retiene la carga la batería, la reemplace con una nueva, la cargó normal la desconecte quedó apagada.
A la mañana siguiente la quise prender y no se pudo por qué la batería estaba totalmente descargada, (lo mismo hacia con la batería anterior)
Que será lo que tiene mi bocina?
Sometimes disassemblers forget that the first time they disassembled the item it didn’t want to give up easily: I didn’t like the forces I was having to apply at all, so I switched to two plastic prying tools per “corner” and one in-between them (total 5, you could use plectrums…) before I was happy the the forces were low enough not to break anything.
Frank Puranik - 답글
the front grill is supposed to be first not the back the back has longer while the front has shorter clip
Water Bass Tester (Water BT) - 답글
There are two Phillips head screws to remove before prying the cover off
jason - 답글
Where in south Africa can I buy jbl charge3 port bay replacement
Donovan Fransman - 답글
There appears to be different versions of the Charge 3. If you find it difficult to pry open a second side the two small screws mentioned by Jason will need to be removed but it also indicates that there will be some additional changes to this tear down that I will try to convey in the comments as well.
john Ramirez - 답글
Sadly I damaged the latches on my charge 3. There was more to it than just prying the front cover up. First, there is a small latch on both sides that you need to push down before pulling the front cover towards you that release the clips holding the front cover in place. Pull only slightly forward because… Second, in the front cover there are 6 circular notches connected to the front cover in tue four corners including the middle corners, you need to squeeze the front cover a little bit gently removing the notches so they dont break (like mine did).
ralphkeneth_gomz - 답글
Definitely had to watch about 10 videos and still couldn’t get it to pop out easily.. Took a look at the first picture in the next step and really took note of where the little hole that lets you through to push down the tab is. Once I took a look at that and combined the techniques I’d seen in some of the videos it finally popped off easily. https://www.youtube.com/watch?v=u7i0_nD9... I only watched the first minute of this video but it helped a good bit if anyone else is having trouble.
Rowan Darko - 답글
How do you know if the speakers or one of them is burned or broken.. i notice that one speaker is playing much less hard then the other one.. I wonder now if maybe there is another problem with my device.. Battery problem?
Bukowski101 - 답글
