주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
JBL Charge 3 Front Cover Replacement
필요한 것
    1. JBL Charge 3 Front Cover Replacement, Front Cover: 1 단계, 이미지 3개 중 1개 JBL Charge 3 Front Cover Replacement, Front Cover: 1 단계, 이미지 3개 중 2개 JBL Charge 3 Front Cover Replacement, Front Cover: 1 단계, 이미지 3개 중 3개
      • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
      • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
      • Repeat this process for all four edges of the front cover.
      댓글 쓰기
    2. JBL Charge 3 Front Cover Replacement: 2 단계, 이미지 1개 중 1개
      • Pull apart your cover gently from both sides and remove it from the speaker housing.
      • There are screws around the foot of the device that may need loosening to be able to unclip the other side of the cover.
      • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
      • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Aidan Hays
회원 가입일: 10/08/18
4,376 평판
안내서 2개를 작성함
Cal Poly, Team S13-G1, White Fall 2018 Cal Poly, Team S13-G1, White Fall 2018 회원
CPSU-WHITE-F18S13G1
3 회원들
안내서 45개를 작성함
2가이드 댓글
where can i buy a new front cover for mine? mine has got cracked
Cammy Innes - 답글 공유
It seems there may be different versions of Charge 3 covers in existence, as when I opened mine (carefully with a slim screwdriver) I was presented with a single cross head screw on each end which was holding one of the ends of the cover in place. I could remove the top end at both ends, but had to unscrew these screws to get the other end off. It was easy, just deviates from this guide quite a bit!
Thomas Hall - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 17
지난 30일: 134
전체 시간: 12,642
