소개
The motherboard is the last piece of your speaker you should try replacing if it is not operating properly as it is the most difficult to access.
  1. Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover. Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place. Repeat this process for all four edges of the front cover.
    • Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
    • Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
    • Repeat this process for all four edges of the front cover.
    Sometimes disassemblers forget that the first time they disassembled the item it didn’t want to give up easily: I didn’t like the forces I was having to apply at all, so I switched to two plastic prying tools per “corner” and one in-between them (total 5, you could use plectrums…) before I was happy the the forces were low enough not to break anything.
    Frank Puranik - 답글
    the front grill is supposed to be first not the back the back has longer while the front has shorter clip
    Water Bass Tester (Water BT) - 답글
    There are two Phillips head screws to remove before prying the cover off
    jason - 답글
  2. Pull apart your cover gently from both sides and remove it from the speaker housing.
    • Pull apart your cover gently from both sides and remove it from the speaker housing.
    • The inside of the front cover has holes that must match with their corresponding pins on the speaker housing for proper reassembly.
    • Removing the Front Cover does not affect the waterproof seals of the device. However, removing any further disassembly of your speaker will require removing waterproof seals and gaskets. Your device may no longer be waterproof after these have been altered.
    Include dissembling the plastic cover? cover?
    KanGoon - 답글
    @KanGoon Yes, on mine it took the removal of 6 (reasonably obvious) screws to remove that. I’ll try to insert a photo when I reassemble…
    Frank Puranik - 답글
    Very good guide! Pics and descriptions make this easy!
    John G Petko - 답글
  3. Remove the two 8mm Phillips #1 screws from the tabs. NOTE: There may be only one screw. NOTE: There may be only one screw.
    • Remove the two 8mm Phillips #1 screws from the tabs.
    • NOTE: There may be only one screw.
  4. Insert  the plastic opening tools underneath both tabs. Insert  the plastic opening tools underneath both tabs.
    • Insert the plastic opening tools underneath both tabs.
    Beim Modell 2016 geht es noch einfacher: Da ist es ein Bajonett-Verschluss (und nur 1 Schraube im vorigen Schritt). Man muss die Abdeckung nur ein paar Grad gegen den Uhrzeigersinn drehen und kann sie dann einfach abziehen. Schritt 5 und 6 entfallen.
    Franz - 답글
  5. Twist and pull open the passive radiator. The left radiator twists off counterclockwise; the right clockwise.
    • Twist and pull open the passive radiator. The left radiator twists off counterclockwise; the right clockwise.
  6. Repeat all previous steps for the other passive radiator. NOTE: only the right radiator needs to be removed for changing the battery.
    • Repeat all previous steps for the other passive radiator.
    • NOTE: only the right radiator needs to be removed for changing the battery.
  7. Remove the eight 10mm Phillips #1 screws from around the two front speakers. Remove the eight 10mm Phillips #1 screws from around the two front speakers.
    • Remove the eight 10mm Phillips #1 screws from around the two front speakers.
    Die Frage : Ist ob man irgendwo Ersatz Lautsprecher bekommt ???
    nicowihnaleck - 답글
    Probier's mal hier, vergleiche aber ganz genau (Seriennummer GG…):
    https://ecommerce.mysav.eu/en/jbl/147-sp...
    VauWeh - 답글
  8. Pull gently on one of the speakers so it is outside of the housing. Be careful as it is still attached with the wires to the motherboard.
    • Pull gently on one of the speakers so it is outside of the housing. Be careful as it is still attached with the wires to the motherboard.
  9. Press the small metal tab on the speaker connector with a Phillips #000 screwdriver and gently pull the connector apart. Press the small metal tab on the speaker connector with a Phillips #000 screwdriver and gently pull the connector apart. Press the small metal tab on the speaker connector with a Phillips #000 screwdriver and gently pull the connector apart.
    • Press the small metal tab on the speaker connector with a Phillips #000 screwdriver and gently pull the connector apart.
    Where can l buy those speaker for replacing
    Terrence Terrence - 답글
    Somebody know where I can buy These speakers ?
    motje - 답글
  10. 안드로이드 수리 키트
    새 스크린 혹은 배터리는 단 하나의 키트로 충분합니다.
    지금 장보기
    안드로이드 수리 키트
    지금 장보기
  11. Repeat the previous step for the second connector.
    • Repeat the previous step for the second connector.
  12. Grab the bundled cable connector that joins the speakers to the motherboard with tweezers. Gently pull the connector free. Grab the bundled cable connector that joins the speakers to the motherboard with tweezers. Gently pull the connector free.
    • Grab the bundled cable connector that joins the speakers to the motherboard with tweezers. Gently pull the connector free.
  13. Now that the second speaker is disconnected from the motherboard, pull the speaker and wires out of the housing.
    • Now that the second speaker is disconnected from the motherboard, pull the speaker and wires out of the housing.
  14. Remove the six 8mm Phillips #1 screws from the outer battery cover. Peel the outer battery cover away from the speaker housing. Peel the outer battery cover away from the speaker housing.
    • Remove the six 8mm Phillips #1 screws from the outer battery cover.
    • Peel the outer battery cover away from the speaker housing.
  15. Remove the seven 8mm Phillips #1 screws from interior battery cover. Remove the interior battery cover. Remove the interior battery cover.
    • Remove the seven 8mm Phillips #1 screws from interior battery cover.
    • Remove the interior battery cover.
  16. Pull gently to disconnect the bundled cable connector in the side of the speaker. This action will separate the battery from the motherboard. Pull gently to disconnect the bundled cable connector in the side of the speaker. This action will separate the battery from the motherboard.
    • Pull gently to disconnect the bundled cable connector in the side of the speaker. This action will separate the battery from the motherboard.
  17. Pull the battery and battery cable out from their housing.
    • Pull the battery and battery cable out from their housing.
    Where can I find (shop) a battery replacement ?
    erik g5 - 답글
    Does anyone know where I can buy a replacement battery?
    Tissaka Senarath - 답글
  18. Take out the four  8mm Phillips #1 screws out of the port bay cover. Wedge your plastic opening tool around the port bay to remove it. Wedge your plastic opening tool around the port bay to remove it.
    • Take out the four 8mm Phillips #1 screws out of the port bay cover.
    • Wedge your plastic opening tool around the port bay to remove it.
    and then wiggle it directly (almost radially from the cylinder) out until you see the cables shown in the next step.
    Be careful not to damage the plastic gasket as you pull it out,
    Frank Puranik - 답글
  19. Disconnect the two bundled cable connector from the port bay. Disconnect the two bundled cable connector from the port bay. Disconnect the two bundled cable connector from the port bay.
    • Disconnect the two bundled cable connector from the port bay.
    there’s not much room to get you fingers in. Again I used prying tools to help me get the two connectors off the PCB
    Frank Puranik - 답글
    How do i get another port bay
    pjimenez98 - 답글
  20. Remove the three 8mm Phillips #1 screws from the port bay circuit board. Pull the port bay cover off of the circuit board. Pull the port bay cover off of the circuit board.
    • Remove the three 8mm Phillips #1 screws from the port bay circuit board.
    • Pull the port bay cover off of the circuit board.
    Be careful not to break the 2 plastic lugs you can see just below (on the photo) the 2 screws at the edges
    Frank Puranik - 답글
  21. Desolder the USB, MicroUSB, or AUX port off of the circuit board. Desolder the USB, MicroUSB, or AUX port off of the circuit board.
    • Desolder the USB, MicroUSB, or AUX port off of the circuit board.
  22. Remove the two  9mm  Phillips #1  screws holding in the sides of the motherboard. Remove the two  9mm  Phillips #1  screws holding in the sides of the motherboard. Remove the two  9mm  Phillips #1  screws holding in the sides of the motherboard.
    • Remove the two 9mm Phillips #1 screws holding in the sides of the motherboard.
  23. Gently pull the bundled cable connector on the motherboard. Gently pull the bundled cable connector on the motherboard.
    • Gently pull the bundled cable connector on the motherboard.
  24. Gently pull the golden connector off of the motherboard. Gently pull the golden connector off of the motherboard.
    • Gently pull the golden connector off of the motherboard.
    Buenos días, se me despegó el otro extremo del cable del conector dorado y quisiera que me indiquen en qué lugar se vuelve a conectar. Muchas gracias
    Javier Cristanchi - 답글
  25. Flip  open the top flap on the two ZIF connectors. Gently pull out the ZIF connector cables with tweezers. Gently pull out the ZIF connector cables with tweezers.
    • Flip open the top flap on the two ZIF connectors.
    • Gently pull out the ZIF connector cables with tweezers.
  26. Slide the motherboard out of the housing.
    • Slide the motherboard out of the housing.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Sunmin Yoon
회원 가입일: 2018년 10월 30일
535 Reputation
안내서 2개 작성하였습니다
Cal Poly, Team S13-G1, White Fall 2018 Cal Poly, Team S13-G1, White Fall 2018 회원
CPSU-WHITE-F18S13G1
4 회원들
안내서 14개 작성하였습니다
댓글 6개
Internation version is different. There are no screws for passive radiotors.
Tr0ll05aur0s 3z - 답글
You have to twist it. I have to managed to get it open because there is no video on youtube (I can’t find any)
Tr0ll05aur0s 3z -
If that even is Charge 3.
Tr0ll05aur0s 3z -
My JBL charge 3 is not charging …please give me idea to fix ..but it’s working perfectly only
nagendra.shriyan - 답글
My jbl charge are charging but it won't turn on…… i have tried several times to turn it on but it won't turn…… hoping for solutions……
cire_012881 - 답글
hello mate! did you find any solution?
baran.florin -
댓글 쓰기
Past 24 Hours: 10
Past 7 Days: 77
Past 30 Days: 374
All Time: 4,155
