이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
The JBL Charge 3 has two front speaker that can be replaced individually or together. If your speakers are blown out replace them with this guide.
필요한 것
Turn your speaker upside down and insert the plastic opening tool vertically into the slit in the front cover.
Slowly pull the plastic opening tool outward to remove the four clips holding the covering in place.
Repeat this process for all four edges of the front cover.
다른 42명이 해당 안내서를 완성하였습니다.
댓글 31개
I need to replace my JBL charge 3 speaker
Where can buy the small speakers? Helpp
Luis Cilia - 답글
I have to pull out the motherboard to get those speakers out.
where can i buy the replacement speakers?
