주요 콘텐츠로 건너뛰기
JBL Charge 4 Passive Bass Radiators Replacement
필요한 것
  1. JBL Charge 4 Passive Bass Radiators Replacement, Speaker Grill: 1 단계, 이미지 1/1
    • Flip your speaker over and insert the plastic opening tool into the slit on the grille.
    • Pry away from yourself towards the back of the speaker to release the clip.
    • Repeat this process for the clip on the other side.
  2. JBL Charge 4 Passive Bass Radiators Replacement: 2 단계, 이미지 1/2 JBL Charge 4 Passive Bass Radiators Replacement: 2 단계, 이미지 2/2
    • Remove the two 8mm Phillips #0 screws from the other edge of the grille.
  3. JBL Charge 4 Passive Bass Radiators Replacement: 3 단계, 이미지 1/1
    • Pull apart both sides of the grille.
    • Lift the cover off of the speaker.
  4. JBL Charge 4 Passive Bass Radiators Replacement, Passive Bass Radiators: 4 단계, 이미지 1/2 JBL Charge 4 Passive Bass Radiators Replacement, Passive Bass Radiators: 4 단계, 이미지 2/2
    • Using the plastic opening tool, lift the tab on top of the speaker to release the radiator from the clips.
    • Repeat this process on the other clips around the radiator to release it from the frame.
  5. JBL Charge 4 Passive Bass Radiators Replacement: 5 단계, 이미지 1/2 JBL Charge 4 Passive Bass Radiators Replacement: 5 단계, 이미지 2/2
    • Push the radiator off of the frame of the device.
    • Repeat on the other side.
    • The passive bass radiators seal out water from inside the device. Removing them multiple times may compromise the waterproof nature of the speaker.
결론
다른 9명이 해당 안내서를 완성하였습니다.
Zachary Colwell
회원 가입일: 01/24/19
1,914 평판
안내서 5개 작성하였습니다
Cal Poly, Team S1-G1, White Winter 2019 Cal Poly, Team S1-G1, White Winter 2019 회원
CPSU-WHITE-W19S1G1
4 회원들
안내서 26개 작성하였습니다
댓글 5개
Exactly where are supposed to get parts for this, do you suppose !?
Yash Bhushan - 답글
It says it on the top of the introduction
Jacob Galeano Garcia -
Hi do you hany any suggestion on where to buy the passive radiators?
Epolu Isaac Tushabe - 답글
Were can i get the main cover from can you help please and the subwoofers
Nate Millette - 답글
Yo tengo la charge 4 y se me rompió uno de los radiadores lo que yo quisiera saber si se pueden arreglar o lo tengo que cambiar por otro
Reynaldo Ronquillo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 17
30일 전: 71
전체 시간: 6,856
