주요 콘텐츠로 건너뛰기
JBL Charge Battery Replacement
필요한 것
  1. JBL Charge Battery Replacement, Disassembling JBL Charge Casing: 1 단계, 이미지 3개 중 1개 JBL Charge Battery Replacement, Disassembling JBL Charge Casing: 1 단계, 이미지 3개 중 2개 JBL Charge Battery Replacement, Disassembling JBL Charge Casing: 1 단계, 이미지 3개 중 3개
    • Make sure the device is powered off before you begin to disassemble the speaker.
    • Remove the trim from the speaker using a jimmy or metal spudger.
  2. JBL Charge Battery Replacement: 2 단계, 이미지 2개 중 1개 JBL Charge Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
    • Remove the battery cover and set the cover aside.
  3. JBL Charge Battery Replacement: 3 단계, 이미지 2개 중 1개 JBL Charge Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
    • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
  4. JBL Charge Battery Replacement: 4 단계, 이미지 2개 중 1개 JBL Charge Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Use a spudger to lift the battery out of the device.
    • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
    • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
  5. JBL Charge Battery Replacement: 5 단계, 이미지 2개 중 1개 JBL Charge Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
  6. JBL Charge Battery Replacement: 6 단계, 이미지 2개 중 1개 JBL Charge Battery Replacement: 6 단계, 이미지 2개 중 2개
    • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
    • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
  7. JBL Charge Battery Replacement: 7 단계, 이미지 2개 중 1개 JBL Charge Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Once the back casing is open, disconnect the three white connectors from the motherboard.
    • Remove the upper casing.
  8. JBL Charge Battery Replacement, Battery: 8 단계, 이미지 1개 중 1개
    • Turn your attention to the back casing removed in Step 7.
  9. JBL Charge Battery Replacement: 9 단계, 이미지 1개 중 1개
    • Using a razor blade, remove the glue holding the battery cable in place.
    • Use multiple vertical cuts to remove pieces of the glue.
    • Be careful not to cut the battery cables.
  10. JBL Charge Battery Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the foam surrounding the battery cable.
  11. JBL Charge Battery Replacement: 11 단계, 이미지 1개 중 1개
    • To remove the battery, pull the battery cable through the hole.
    • This entire white piece needs to be replaced (if replacing the aux/usb port).
결론
다른 38명이 해당 안내서를 완성하였습니다.
작성자
12다른 기여자 명과 함께
Joe Durand
회원 가입일: 04/01/15
2,221 평판
안내서 2개를 작성함
Cal Poly, Team 12-4, Lancaster Spring 2015 Cal Poly, Team 12-4, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G4
2 회원들
안내서 20개를 작성함
32가이드 댓글
How i replaced a new battery in myjbl reflect headphone bluetooth
Mohamad Lutfi - 답글
Please I need directions on replacing the battery of my jbl pulse speaker because it charges but doesn't indicate battery charging nor does it work.please I will be ver grateful.
Ifeanyi(kazhbone0147@gmail.com)
Ifeanyi Anaetoh - 답글
I need help.
My speaker no longer takes a charge.
Not even that old
Where do I get replacement battery. And what kind
Rose -
Your instructions state to replace the white cover, but do not say why it has to be replaced. Can you expound, please? Thank you,
Delton Eason Jr - 답글
Hi Delton, that is a good question. The entire cover has to be replaced if one is replacing the aux/USB ports.
You can ignore that note in this battery replacement guide. Good catch!
Joe Durand -
댓글 쓰기
조회 통계:
지난 24시간: 13
지난 7일: 90
지난 30일: 362
전체 시간: 232,256
