주요 콘텐츠로 건너뛰기
JBL Charge Button Membrane Replacement
필요한 것
  1. JBL Charge Button Membrane Replacement, Disassembling JBL Charge Casing: 1 단계, 이미지 3개 중 1개 JBL Charge Button Membrane Replacement, Disassembling JBL Charge Casing: 1 단계, 이미지 3개 중 2개 JBL Charge Button Membrane Replacement, Disassembling JBL Charge Casing: 1 단계, 이미지 3개 중 3개
    • Make sure the device is powered off before you begin to disassemble the speaker.
    • Remove the trim from the speaker using a jimmy or metal spudger.
  2. JBL Charge Button Membrane Replacement: 2 단계, 이미지 2개 중 1개 JBL Charge Button Membrane Replacement: 2 단계, 이미지 2개 중 2개
    • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
    • Remove the battery cover and set the cover aside.
  3. JBL Charge Button Membrane Replacement: 3 단계, 이미지 2개 중 1개 JBL Charge Button Membrane Replacement: 3 단계, 이미지 2개 중 2개
    • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
    • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
  4. JBL Charge Button Membrane Replacement: 4 단계, 이미지 2개 중 1개 JBL Charge Button Membrane Replacement: 4 단계, 이미지 2개 중 2개
    • Use a spudger to lift the battery out of the device.
    • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
    • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
  5. JBL Charge Button Membrane Replacement: 5 단계, 이미지 2개 중 1개 JBL Charge Button Membrane Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
  6. JBL Charge Button Membrane Replacement: 6 단계, 이미지 2개 중 1개 JBL Charge Button Membrane Replacement: 6 단계, 이미지 2개 중 2개
    • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
    • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
  7. JBL Charge Button Membrane Replacement: 7 단계, 이미지 2개 중 1개 JBL Charge Button Membrane Replacement: 7 단계, 이미지 2개 중 2개
    • Once the back casing is open, disconnect the three white connectors from the motherboard.
    • Remove the upper casing.
  8. JBL Charge Button Membrane Replacement, Motherboard: 8 단계, 이미지 1개 중 1개
    • Remove the 9 mm Phillips screw in the corner of the motherboard.
  9. JBL Charge Button Membrane Replacement: 9 단계, 이미지 2개 중 1개 JBL Charge Button Membrane Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the motherboard from the casing by lifting the corner of the board out of the device.
    • If the motherboard won't budge, be sure that the square component on the bottom of the motherboard clears the edge of the speaker.
    • During reassembly, make sure the motherboard is fully installed and not sticking up past its original position, as this could damage the motherboard.
  10. JBL Charge Button Membrane Replacement: 10 단계, 이미지 1개 중 1개
    • Disconnect the two white connectors from the bottom of the motherboard.
  11. JBL Charge Button Membrane Replacement: 11 단계, 이미지 2개 중 1개 JBL Charge Button Membrane Replacement: 11 단계, 이미지 2개 중 2개
    • Pull down on the black clip holding the ribbon cable in place.
    • Pull the ribbon cable from the connector using the blue tab.
    • Remove the motherboard from the device.
  12. JBL Charge Button Membrane Replacement, Button Membrane: 12 단계, 이미지 1개 중 1개
    • Locate the buttons on top of the device. Peel the white piece of tape located along the side of this button membrane.
  13. JBL Charge Button Membrane Replacement: 13 단계, 이미지 1개 중 1개
    • Gently pull out the button membrane. You should not expect much resistance.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Jake Bertholf
회원 가입일: 04/01/15
378 평판
안내서 2개를 작성함
Cal Poly, Team 12-1, Lancaster Spring 2015 Cal Poly, Team 12-1, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G1
5 회원들
안내서 11개를 작성함
2가이드 댓글
conseguiste el boton de repuesto?
Mario A Vargas S - 답글
Por favor, disculpe mis errores:
"No puedo encontrar un nuevo reemplazo. Compra uno roto. Utilice el botón de la que se rompe."
Joe Durand -
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 45
전체 시간: 10,154
