주요 콘텐츠로 건너뛰기
JBL Charge Motherboard Replacement
필요한 것
  1. JBL Charge Motherboard Replacement, Disassembling JBL Charge Casing: 1 단계, 이미지 1/3 JBL Charge Motherboard Replacement, Disassembling JBL Charge Casing: 1 단계, 이미지 2/3 JBL Charge Motherboard Replacement, Disassembling JBL Charge Casing: 1 단계, 이미지 3/3
    • Make sure the device is powered off before you begin to disassemble the speaker.
    • Remove the trim from the speaker using a jimmy or metal spudger.
  2. JBL Charge Motherboard Replacement: 2 단계, 이미지 1/2 JBL Charge Motherboard Replacement: 2 단계, 이미지 2/2
    • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
    • Remove the battery cover and set the cover aside.
  3. JBL Charge Motherboard Replacement: 3 단계, 이미지 1/2 JBL Charge Motherboard Replacement: 3 단계, 이미지 2/2
    • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
    • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
  4. JBL Charge Motherboard Replacement: 4 단계, 이미지 1/2 JBL Charge Motherboard Replacement: 4 단계, 이미지 2/2
    • Use a spudger to lift the battery out of the device.
    • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
    • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
  5. JBL Charge Motherboard Replacement: 5 단계, 이미지 1/2 JBL Charge Motherboard Replacement: 5 단계, 이미지 2/2
    • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
  6. JBL Charge Motherboard Replacement: 6 단계, 이미지 1/2 JBL Charge Motherboard Replacement: 6 단계, 이미지 2/2
    • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
    • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
  7. JBL Charge Motherboard Replacement: 7 단계, 이미지 1/2 JBL Charge Motherboard Replacement: 7 단계, 이미지 2/2
    • Once the back casing is open, disconnect the three white connectors from the motherboard.
    • Remove the upper casing.
  8. JBL Charge Motherboard Replacement, Motherboard: 8 단계, 이미지 1/1
    • Remove the 9 mm Phillips screw in the corner of the motherboard.
  9. JBL Charge Motherboard Replacement: 9 단계, 이미지 1/2 JBL Charge Motherboard Replacement: 9 단계, 이미지 2/2
    • Remove the motherboard from the casing by lifting the corner of the board out of the device.
    • If the motherboard won't budge, be sure that the square component on the bottom of the motherboard clears the edge of the speaker.
    • During reassembly, make sure the motherboard is fully installed and not sticking up past its original position, as this could damage the motherboard.
  10. JBL Charge Motherboard Replacement: 10 단계, 이미지 1/1
    • Disconnect the two white connectors from the bottom of the motherboard.
  11. JBL Charge Motherboard Replacement: 11 단계, 이미지 1/2 JBL Charge Motherboard Replacement: 11 단계, 이미지 2/2
    • Pull down on the black clip holding the ribbon cable in place.
    • Pull the ribbon cable from the connector using the blue tab.
    • Remove the motherboard from the device.
결론
다른 7명이 해당 안내서를 완성하였습니다.
Jake Bertholf
회원 가입일: 04/01/15
351 평판
안내서 2개 작성하였습니다
Cal Poly, Team 12-1, Lancaster Spring 2015 Cal Poly, Team 12-1, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G1
5 회원들
안내서 10개 작성하였습니다
댓글 14개
Hello I have 3 jbl speakers I bought that work only if plugged to the wall and aux cable... other than that it doesn't work at all .. Bluetooth or even the buttons don't function
hector - 답글
had same issue. fixed it by reconnecting the cable that conncts LEDs/ buttons
nyancatsarecute -
i have the same problem
Denny Berroa - 답글
Hello, mine doesn't emit any sound, bluetooth is connected, buttons are working, could it be that some audio cable inside is disconnected?
giubo - 답글
hello can i ask if how many pins in the flex for power button i accidentally damage when i fixed it
djcriztorey - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 17
30일 전: 67
전체 시간: 29,652
