주요 콘텐츠로 건너뛰기
JBL Charge Speaker Replacement
필요한 것
  1. JBL Charge Speaker Replacement, Disassembling JBL Charge Casing: 1 단계, 이미지 1/3 JBL Charge Speaker Replacement, Disassembling JBL Charge Casing: 1 단계, 이미지 2/3 JBL Charge Speaker Replacement, Disassembling JBL Charge Casing: 1 단계, 이미지 3/3
    • Make sure the device is powered off before you begin to disassemble the speaker.
    • Remove the trim from the speaker using a jimmy or metal spudger.
  2. JBL Charge Speaker Replacement: 2 단계, 이미지 1/2 JBL Charge Speaker Replacement: 2 단계, 이미지 2/2
    • Use the PH1 screwdriver to remove all five of the 6 mm screws from the battery cover.
    • Remove the battery cover and set the cover aside.
  3. JBL Charge Speaker Replacement: 3 단계, 이미지 1/2 JBL Charge Speaker Replacement: 3 단계, 이미지 2/2
    • Use a spudger to carefully remove the liquid electrical tape that holds the battery inside the battery compartment.
    • Be careful not to puncture the battery, or damage the battery wire underneath the liquid electrical tape.
  4. JBL Charge Speaker Replacement: 4 단계, 이미지 1/2 JBL Charge Speaker Replacement: 4 단계, 이미지 2/2
    • Use a spudger to lift the battery out of the device.
    • Lift the end of the battery that does not have the wire connection and remove the 16 mm PH2 screw underneath the battery.
    • Notice the wire that is connecting the battery to the device. Attempting to remove the battery completely could cause damage to the wire. Do not use a metal spudger to remove the battery, this could cause damage.
  5. JBL Charge Speaker Replacement: 5 단계, 이미지 1/2 JBL Charge Speaker Replacement: 5 단계, 이미지 2/2
    • Remove the four 16 mm screws from the white plastic casing using the PH2 screwdriver.
  6. JBL Charge Speaker Replacement: 6 단계, 이미지 1/2 JBL Charge Speaker Replacement: 6 단계, 이미지 2/2
    • Starting in a corner of the device where the casing and the side meet, use a pointed metal spudger to pry the back casing off the speaker and the glue holding the seam together.
    • Slide the metal spudger along the seam to separate the back casing from the rest of the speaker.
  7. JBL Charge Speaker Replacement: 7 단계, 이미지 1/2 JBL Charge Speaker Replacement: 7 단계, 이미지 2/2
    • Once the back casing is open, disconnect the three white connectors from the motherboard.
    • Remove the upper casing.
  8. JBL Charge Speaker Replacement, Motherboard: 8 단계, 이미지 1/1
    • Remove the 9 mm Phillips screw in the corner of the motherboard.
  9. JBL Charge Speaker Replacement: 9 단계, 이미지 1/2 JBL Charge Speaker Replacement: 9 단계, 이미지 2/2
    • Remove the motherboard from the casing by lifting the corner of the board out of the device.
    • If the motherboard won't budge, be sure that the square component on the bottom of the motherboard clears the edge of the speaker.
    • During reassembly, make sure the motherboard is fully installed and not sticking up past its original position, as this could damage the motherboard.
  10. JBL Charge Speaker Replacement: 10 단계, 이미지 1/1
    • Disconnect the two white connectors from the bottom of the motherboard.
  11. JBL Charge Speaker Replacement: 11 단계, 이미지 1/2 JBL Charge Speaker Replacement: 11 단계, 이미지 2/2
    • Pull down on the black clip holding the ribbon cable in place.
    • Pull the ribbon cable from the connector using the blue tab.
    • Remove the motherboard from the device.
  12. JBL Charge Speaker Replacement, Speaker: 12 단계, 이미지 1/1
    • Using the PH1 screwdriver, remove the 9mm Phillips screw that connects the black tube to the device's interior.
  13. JBL Charge Speaker Replacement: 13 단계, 이미지 1/2 JBL Charge Speaker Replacement: 13 단계, 이미지 2/2
    • Slowly but firmly pull the grey cap off the device. This will provide complete access to the speakers.
  14. JBL Charge Speaker Replacement: 14 단계, 이미지 1/2 JBL Charge Speaker Replacement: 14 단계, 이미지 2/2
    • Each speaker is held in place with two 9mm Phillips screws. Remove the screws using the PH1 screwdriver head.
    • If you are replacing the left speaker, remove the screws and speaker on your right.
    • If you are replacing the right speaker, remove the screws and speaker on your left.
  15. JBL Charge Speaker Replacement: 15 단계, 이미지 1/1
    • Pull the speaker out of the casing.
결론
다른 14명이 해당 안내서를 완성하였습니다.
Alexander Castanares
회원 가입일: 04/01/15
867 평판
안내서 2개 작성하였습니다
Cal Poly, Team 12-4, Lancaster Spring 2015 Cal Poly, Team 12-4, Lancaster Spring 2015 회원
CPSU-LANCASTER-S15S12G4
2 회원들
안내서 17개 작성하였습니다
댓글 11개
Donde encuentro las bocinas no sirven la que tiene
feliper233 - 답글
Donde puedo conseguir las bocinas?
feliper233 - 답글
Where can I get gthe replacement speaker?
rohit jayendra - 답글
where can i get replaicment speaker?
tamaerocksxd - 답글
Where do I get the replacement speakers
Robert - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 35
30일 전: 139
전체 시간: 80,724
