주요 콘텐츠로 건너뛰기
JBL Clip 2 Audio AUX Cord Replacement
필요한 것
  1. JBL Clip 2 Audio AUX Cord Replacement, Audio AUX Cord: 1 단계, 이미지 1/1
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Audio AUX Cord Replacement: 2 단계, 이미지 1/1
    • There will be six 3 mm T8 screws under the cap, remove these six screws. Save
    • If you are not trying to replace the speaker please ignore the two middle 3 mm T8 screws during this procedure.
  3. JBL Clip 2 Audio AUX Cord Replacement: 3 단계, 이미지 1/1
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Audio AUX Cord Replacement: 4 단계, 이미지 1/1
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
  5. JBL Clip 2 Audio AUX Cord Replacement: 5 단계, 이미지 1/1
    • There will be four 3 mm T8 screws holding the motherboard in place, remove these four screws.
  6. JBL Clip 2 Audio AUX Cord Replacement: 6 단계, 이미지 1/1
결론
다른 3명이 해당 안내서를 완성하였습니다.
Michael Hong
회원 가입일: 02/01/17
1,014 평판
안내서 5개 작성하였습니다
UW Tacoma, Team 2-2, Rose Winter 2017 UW Tacoma, Team 2-2, Rose Winter 2017 회원
UWT-ROSE-W17S2G2
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
<a href="https://www.w3schools.com/">Visit W3Schools.com!</a>
pavan kalyan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 20
전체 시간: 3,591
