소개
The carabineer on the JBL Clip 2 is removable. If the carabineer mount does not work, you will notice that the device will no longer clip on to secure locations. If this is the case the carabineer mount will have to be replaced. The device will be taken apart and the carabineer mount will be removed and replaced.
필요한 것
Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 2개
i want to find that part ,dou you have web link to by
