주요 콘텐츠로 건너뛰기
JBL Clip 2 Speaker Replacement
필요한 것
  1. JBL Clip 2 Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Begin by removing the front cap of the JBL Clip 2 by using the blue plastic opening tool to get in between the creases.
    • If your JBL Clip 2 has never been opened this procedure will require moderate amount of force.
  2. JBL Clip 2 Speaker Replacement: 2 단계, 이미지 1/1
    • There will be six 3 mm T8 screws under the cap, remove these six screws.
  3. JBL Clip 2 Speaker Replacement: 3 단계, 이미지 1/1
    • The front cover will lift open easily and the components will be visible.
  4. JBL Clip 2 Speaker Replacement: 4 단계, 이미지 1/1
    • To completely remove the top portion, disconnect the speaker from the motherboard using the blue plastic opening tool.
    • While disconnecting be sure to not use too much force as these two parts are meant to become disconnected.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Michael Hong
회원 가입일: 02/01/17
1,014 평판
안내서 5개 작성하였습니다
UW Tacoma, Team 2-2, Rose Winter 2017 UW Tacoma, Team 2-2, Rose Winter 2017 회원
UWT-ROSE-W17S2G2
4 회원들
안내서 7개 작성하였습니다
댓글 6개
If no parts are required what are you replacing the speaker with?
Tom - 답글
Tom is right you know!
edward felix - 답글
The grill was glued into the T8 recesses. It needs glue to resemble. But how not to ruin the T8 heads for future work?
Gus Cannon - 답글
please we need to know where we can buy replacement speakers thanks email: chris.vargasrobles@gmail.com
chris robles - 답글
Hi, where I can buy the speaker please? Thank you.
Govan - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 56
전체 시간: 6,485
