주요 콘텐츠로 건너뛰기
JBL Clip 3 Speaker Housing Replacement
필요한 것
  1. JBL Clip 3 Speaker Housing Replacement, Speaker Grill: 1 단계, 이미지 1/2 JBL Clip 3 Speaker Housing Replacement, Speaker Grill: 1 단계, 이미지 2/2
    • Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
    • A strong adhesive attaches the grill to the housing, and requires some time and patience to break. Use mild heat to loosen the adhesive if necessary.
  2. JBL Clip 3 Speaker Housing Replacement, Speaker Housing: 2 단계, 이미지 1/2 JBL Clip 3 Speaker Housing Replacement, Speaker Housing: 2 단계, 이미지 2/2
    • Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
  3. JBL Clip 3 Speaker Housing Replacement: 3 단계, 이미지 1/1
    • Separate the speaker housing from the rest of the body.
    • This requires minimal force; they are not glued together.
  4. JBL Clip 3 Speaker Housing Replacement: 4 단계, 이미지 1/2 JBL Clip 3 Speaker Housing Replacement: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Use tweezers to remove the 2 pin and 4 pin connectors from the motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Kyle Montague
회원 가입일: 03/28/22
238 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 1-5, Petersen Spring 2022 UMass Dartmouth, Team 1-5, Petersen Spring 2022 회원
UMASSD-PETERSEN-S22S1G5
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 12
30일 전: 64
전체 시간: 1,302
