소개
This guide is to help you replace the internal speaker in a JBL Clip 3.
If the original speaker in your JBL Clip 3 stops working due to a mechanical failure and causes the speaker to produce no sound at all or an unpleasant buzzing or scratching sound, use this guide to replace it with a new speaker.
Note: Before beginning, make sure to power off the JBL Clip 3, and disconnect it from any external power sources.
필요한 것
Insert the iFixit opening tool between the speaker grill and speaker housing and pry around the entire perimeter of the device until the grill releases.
Use a Phillips #1 screwdriver to remove the five 6.3 mm screws around the perimeter.
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
Excelente información, dónde puedo conseguir altavoz de repuesto ?
