주요 콘텐츠로 건너뛰기
JBL Flip 3 Front Active Driver Replacement
필요한 것
  1. JBL Flip 3 Front Active Driver Replacement, Front Active Driver: 1 단계, 이미지 1/1
    • Remove plastic outer housing using hands or a standard spudger.
  2. JBL Flip 3 Front Active Driver Replacement: 2 단계, 이미지 1/1
    • Using your hands, carefully remove outer housing and frame to expose the internal workings of the speaker.
  3. JBL Flip 3 Front Active Driver Replacement: 3 단계, 이미지 1/1
    • Remove the 8.9mm Phillips #00 screws on each corner of the driver to be replaced. There are four screws per driver. Be sure to set the screws somewhere safe to ensure they aren’t lost.
  4. JBL Flip 3 Front Active Driver Replacement: 4 단계, 이미지 1/1
    • Remove the 3-pin connector from motherboard.
결론
다른 16명이 해당 안내서를 완성하였습니다.
College Student
회원 가입일: 02/22/17
3,479 평판
안내서 4개 작성하였습니다
USF Tampa, Team S1-G2, Leahy Spring 2017 USF Tampa, Team S1-G2, Leahy Spring 2017 회원
USFT-LEAHY-S17S1G2
5 회원들
안내서 17개 작성하였습니다
댓글 7개
where did you source the drivers from?
Rashid Saad Siddiqui - 답글
hi my flip 3 1 speaker is have give the problem thats not give the clear voice , so i want to change the parts can u help me i am where to buy this parts
manu - 답글
I too want to know where you can buy new drivers. Can't find them online so far...
Johannes - 답글
i need help getting the front speakers only where would i get them???
brian ortiz - 답글
Sir
my flip 3 Both speaker is have give the problem thats not give the clear voice , so i want to change the parts can u help me i am where to buy this parts
Anil Kumar Hembrom - 답글
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 18
30일 전: 96
전체 시간: 19,364
