주요 콘텐츠로 건너뛰기
JBL Flip 3 Power Circuit Board Replacement
필요한 것
  1. JBL Flip 3 Power Circuit Board Replacement, Power Circuit Board: 1 단계, 이미지 1/1
    • Remove plastic outer housing using hands or a standard spudger.
    • Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
  2. JBL Flip 3 Power Circuit Board Replacement: 2 단계, 이미지 1/1
    • Carefully remove outer housing to expose the inner components of the speaker.
  3. JBL Flip 3 Power Circuit Board Replacement: 3 단계, 이미지 1/1
    • Remove the silicone button cover to expose the power chip.
  4. JBL Flip 3 Power Circuit Board Replacement: 4 단계, 이미지 1/1
    • Heat the adhesive at the far end of the chip where the ribbon goes down into the device. Using the spudger, gently pry the chip off the board. Be careful not to melt the plastic edging during heating.
    • Heat gun safety: http://www.powertoolinstitute.com/pti_pd...
결론
다른 14명이 해당 안내서를 완성하였습니다.
James Bianco
회원 가입일: 02/20/17
151 평판
안내서 1개 작성함
USF Tampa, Team S1-G2, Leahy Spring 2017 USF Tampa, Team S1-G2, Leahy Spring 2017 회원
USFT-LEAHY-S17S1G2
5 회원들
안내서 17개 작성하였습니다
댓글 5개
If your gentle, you don’t need a heat gun. I carefully removed it with a screwdriver. Just don’t stress the board else your in a new set of problems.
Tyler Freeman - 답글
How do you remove the board? It says to remove the chip from the board but there are no images that show that.
Brian Barlow - 답글
The title says replacement, and you show only the removal.
Stanimir Nikolov - 답글
what could be a problem with my jbl flip 3.it wouldn't turn on when its not plugged in to the charger.
Miss D - 답글
Change the battery
odii Emmanuel -
댓글 쓰기
조회 통계:
24 시간 전: 16
7일 전: 38
30일 전: 212
전체 시간: 30,400
