주요 콘텐츠로 건너뛰기
JBL Flip 3 Side Passive Driver Replacement
필요한 것
  1. JBL Flip 3 Side Passive Driver Replacement, Side Passive Driver: 1 단계, 이미지 1/1
    • Remove the plastic outer housing using your hands or a standard spudger.
    • Important! Note the three alignment pins on the inner part of the housing. When reassembling, take special care to line these up and insert the pins into the receivers on the chassis prior to snapping the edges into place.
  2. JBL Flip 3 Side Passive Driver Replacement: 2 단계, 이미지 1/1
    • Use your hands to carefully remove the outer frame to expose the inner components of the speaker.
  3. JBL Flip 3 Side Passive Driver Replacement: 3 단계, 이미지 1/1
    • Go around the outer edge of the side passive driver with a screwdriver to remove the seven 8.9mm Phillips #00 screws from both sides of the device. Make sure to set the screws aside somewhere they won’t get lost.
  4. JBL Flip 3 Side Passive Driver Replacement: 4 단계, 이미지 1/2 JBL Flip 3 Side Passive Driver Replacement: 4 단계, 이미지 2/2
    • Remove the side passive driver.
결론
다른 5명이 해당 안내서를 완성하였습니다.
College Student
회원 가입일: 02/22/17
3,479 평판
안내서 4개 작성하였습니다
USF Tampa, Team S1-G2, Leahy Spring 2017 USF Tampa, Team S1-G2, Leahy Spring 2017 회원
USFT-LEAHY-S17S1G2
5 회원들
안내서 17개 작성하였습니다
댓글 2개
What the fock?!?!? Ohhh, you basterds. I see what kind of game you're playing. I'm coming to get ya'. I'm gonna track you down, so help me God. I won't rest until I feel the warm, sticky blood of this author, and anybody that looks like him!! I will have my vengeance! I shall reign down upon him like a…(ding!) Ooohh! My toaster pastries!
Johnny Johnson - 답글
Do you know what would be great? If we could source these diaphrams, or speakers, or whatever is being shown here to replace. They are nearly impossible to source!!
Muhip Tuna Meti - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 16
30일 전: 80
전체 시간: 10,476
