주요 콘텐츠로 건너뛰기
JBL Flip 3 Speaker Replacement
필요한 것
  1. JBL Flip 3 Speaker Replacement, Removing Speaker Grill Part 1: 1 단계, 이미지 1/3 JBL Flip 3 Speaker Replacement, Removing Speaker Grill Part 1: 1 단계, 이미지 2/3 JBL Flip 3 Speaker Replacement, Removing Speaker Grill Part 1: 1 단계, 이미지 3/3
    • Using a pry opening tool, pry into the speaker grill covering as seen in the photos.
  2. JBL Flip 3 Speaker Replacement, Removing Speaker Grill Part 2: 2 단계, 이미지 1/3 JBL Flip 3 Speaker Replacement, Removing Speaker Grill Part 2: 2 단계, 이미지 2/3 JBL Flip 3 Speaker Replacement, Removing Speaker Grill Part 2: 2 단계, 이미지 3/3
    • Continue to pry open the grill all the way around until it can be removed from the unit itself as seen in the pictures.
  3. JBL Flip 3 Speaker Replacement, Remove Speaker Screws: 3 단계, 이미지 1/1
    • Remove all 8 speaker screws using a Philips 00 screwdriver.
  4. JBL Flip 3 Speaker Replacement, Remove Speaker from Housing: 4 단계, 이미지 1/2 JBL Flip 3 Speaker Replacement, Remove Speaker from Housing: 4 단계, 이미지 2/2
    • Using a pry tool, remove speakers from housing as seen in the picture.
  5. JBL Flip 3 Speaker Replacement, Remove Speaker Connection: 5 단계, 이미지 1/2 JBL Flip 3 Speaker Replacement, Remove Speaker Connection: 5 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Using tweezers, carefully remove both side speakers from the motherboard as shown in the pictures.
결론
다른 17명이 해당 안내서를 완성하였습니다.
Faizan Naveed
회원 가입일: 04/12/17
3,294 평판
안내서 8개 작성하였습니다
Mobile Device Repair Factory Mobile Device Repair Factory 회원
Business
1 회원
안내서 16개 작성하였습니다
댓글 16개
where did you aquire the replacement drivers?
djbadandy - 답글
where did you get the drivers from?
Rashid Saad Siddiqui - 답글
Sir
My JBL speaker is brust plz help me
Anil Kumar Hembrom - 답글
ANIL KUMAR HEMBROM - 답글
My JBL speaker is brust plz help me ….
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 23
30일 전: 125
전체 시간: 25,048
