주요 콘텐츠로 건너뛰기
JBL Flip 4 Front Active Speaker Replacement
필요한 것
  1. JBL Flip 4 Front Active Speaker Replacement, Front Active Speaker: 1 단계, 이미지 3개 중 1개 JBL Flip 4 Front Active Speaker Replacement, Front Active Speaker: 1 단계, 이미지 3개 중 2개 JBL Flip 4 Front Active Speaker Replacement, Front Active Speaker: 1 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, it will make a snapping sound.
    • Pull off the cover with your thumbs.
  2. JBL Flip 4 Front Active Speaker Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all four 10 mm JIS #1 screws around the damaged front active speaker.
    • The speakers are strong magnets. Keep metal tools or other magnetic objects away from the driver.
  3. JBL Flip 4 Front Active Speaker Replacement: 3 단계, 이미지 3개 중 1개 JBL Flip 4 Front Active Speaker Replacement: 3 단계, 이미지 3개 중 2개 JBL Flip 4 Front Active Speaker Replacement: 3 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool under the unscrewed front active speaker.
    • Pry off the front active speaker with the opening tool.
    • Do not yank the front active speaker out. It is connected to wires within the device.
  4. JBL Flip 4 Front Active Speaker Replacement: 4 단계, 이미지 1개 중 1개
    • Cut the red, white, and black wires connected to the speaker using wire cutters.
    • You will need to re-solder these wires when installing the new speaker.
결론
다른 14명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Ryan Whitlock
회원 가입일: 10/08/18
2,281 평판
안내서 1개를 작성함
Cal Poly, Team S4-G3, White Fall 2018 Cal Poly, Team S4-G3, White Fall 2018 회원
CPSU-WHITE-F18S4G3
4 회원들
안내서 37개를 작성함
댓글 16개
And where can you find the replacement part? I cannot find a replacement speaker on the internet…
Sven Meirsman - 답글
Exactly, what is the part number for the internal speaker?
Dan The Menace Brenes - 답글
The part number is: psp00018001
Johankat -
If the magnet comes loose from the speaker how do you get it back on?
Andrew Sumahit - 답글
Replace the entire speaker.
Magnet realignment is crucial for the speaker to perform properly.
Johankat -
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 65
지난 30일: 213
전체 시간: 38,155
