주요 콘텐츠로 건너뛰기
JBL Flip 4 Shell Replacement
필요한 것
  1. JBL Flip 4 Shell Replacement, Shell: 1 단계, 이미지 3개 중 1개 JBL Flip 4 Shell Replacement, Shell: 1 단계, 이미지 3개 중 2개 JBL Flip 4 Shell Replacement, Shell: 1 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
    • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
    • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
    • Watch out not to damage the clips on the buttons' side, pry open with caution.
    • Pull the cover off with your thumbs.
  2. JBL Flip 4 Shell Replacement: 2 단계, 이미지 3개 중 1개 JBL Flip 4 Shell Replacement: 2 단계, 이미지 3개 중 2개 JBL Flip 4 Shell Replacement: 2 단계, 이미지 3개 중 3개
    • Remove four 13 mm JIS #0 screws attaching the rubber spine to the speaker, located on both sides of the inside of the speaker.
    • Use the plastic opening tool to release the clips holding the central part of the rubber spine.
    • Pry away one end of the rubber spine with your thumbs and it should come off.
    • Prying off the spine may take some persuading.
    • The speakers are strong magnets. Keep it away from other sensitive electronics.
결론
다른 8명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Philip Pang
회원 가입일: 10/08/18
1,314 평판
안내서 4개를 작성함
Cal Poly, Team S4-G3, White Fall 2018 Cal Poly, Team S4-G3, White Fall 2018 회원
CPSU-WHITE-F18S4G3
4 회원들
안내서 37개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 32
지난 30일: 113
전체 시간: 15,006
