소개
If the device will not charge and you have either tried a different working outlet or a different charger or even replaced the battery in the JBL Flip 5 speaker, you may want to try replacing the charging port.
필요한 것
Insert the flat edge of the metal spudger underneath the corner of the outer case.
Use the spudger to pry open the plastic clips that secure the outer case.
Use a Phillips screwdriver to remove the four 17mm-long screws securing the passive radiator bracket.
거의 끝나갑니다!
결론
