주요 콘텐츠로 건너뛰기
JBL Flip 5 Outer Case Replacement
필요한 것
  1. JBL Flip 5 Outer Case Replacement, Outer Case: 1 단계, 이미지 1/2 JBL Flip 5 Outer Case Replacement, Outer Case: 1 단계, 이미지 2/2
    • Insert the flat edge of the metal spudger underneath the corner of the outer case.
    • Use the spudger to pry open the plastic clips that secure the outer case.
  2. JBL Flip 5 Outer Case Replacement: 2 단계, 이미지 1/1
    • Once all the clips are released, you will be able to pull up that edge of the case.
  3. JBL Flip 5 Outer Case Replacement: 3 단계, 이미지 1/1
    • Once one side is released, complete the previous two steps with the other side.
    • This side contains the buttons, so be careful so as to not damage them while prying the case off.
  4. JBL Flip 5 Outer Case Replacement: 4 단계, 이미지 1/2 JBL Flip 5 Outer Case Replacement: 4 단계, 이미지 2/2
    • Once all the clips are removed, you can gently remove the outer case.
    • The case is now fully removed. Now a new case will be attached by putting the case into position and pushing on the clips to reattach them.
결론
Jackson Tillinghast
회원 가입일: 10/30/23
303 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team 3-5, Konn Fall 2023 UMass Dartmouth, Team 3-5, Konn Fall 2023 회원
UMASSD-KONN-F23S3G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 16
30일 전: 49
전체 시간: 192
