주요 콘텐츠로 건너뛰기
JBL Flip 6 Charging Port Replacement
필요한 것
  1. JBL Flip 6 Charging Port Replacement, Case: 1 단계, 이미지 2개 중 1개 JBL Flip 6 Charging Port Replacement, Case: 1 단계, 이미지 2개 중 2개
    • Using the iFixit opening tool, pry up on the button side of the slot on the case until the clips release.
  2. JBL Flip 6 Charging Port Replacement: 2 단계, 이미지 2개 중 1개 JBL Flip 6 Charging Port Replacement: 2 단계, 이미지 2개 중 2개
    • Now that the gap is larger, using the same tool, pry up on the other side until the clips release.
  3. JBL Flip 6 Charging Port Replacement: 3 단계, 이미지 3개 중 1개 JBL Flip 6 Charging Port Replacement: 3 단계, 이미지 3개 중 2개 JBL Flip 6 Charging Port Replacement: 3 단계, 이미지 3개 중 3개
    • With all clips released, slide the case off longways.
    • You may need to spread it a bit with your hands so that the clips do not become caught on the end pieces.
  4. JBL Flip 6 Charging Port Replacement, Passive Radiators: 4 단계, 이미지 2개 중 1개 JBL Flip 6 Charging Port Replacement, Passive Radiators: 4 단계, 이미지 2개 중 2개
    • Use a prying tool to lift up on one of the clips that holds the radiator in place.
  5. JBL Flip 6 Charging Port Replacement: 5 단계, 이미지 2개 중 1개 JBL Flip 6 Charging Port Replacement: 5 단계, 이미지 2개 중 2개
    • After the clip has been released, insert a shim to keep the parts separated and from the clipping back together.
    • Pry on the clip on the other side to fully release the passive radiator.
  6. JBL Flip 6 Charging Port Replacement: 6 단계, 이미지 3개 중 1개 JBL Flip 6 Charging Port Replacement: 6 단계, 이미지 3개 중 2개 JBL Flip 6 Charging Port Replacement: 6 단계, 이미지 3개 중 3개
    • After both clips have been detached, the passive radiator is easier to remove by hand.
    • Repeat the same steps for the passive radiator on the other side.
  7. JBL Flip 6 Charging Port Replacement, Woofer: 7 단계, 이미지 3개 중 1개 JBL Flip 6 Charging Port Replacement, Woofer: 7 단계, 이미지 3개 중 2개 JBL Flip 6 Charging Port Replacement, Woofer: 7 단계, 이미지 3개 중 3개
    • Remove the four 9.5 mm Philips #1 screws securing the woofer to the device.
  8. JBL Flip 6 Charging Port Replacement: 8 단계, 이미지 3개 중 1개 JBL Flip 6 Charging Port Replacement: 8 단계, 이미지 3개 중 2개 JBL Flip 6 Charging Port Replacement: 8 단계, 이미지 3개 중 3개
    • Carefully disconnect the white connector linking the woofer and the motherboard.
    • If there is a lot of resistance when removing the plug, there could be a clip holding it in place. Check for any sort of fasteners before using much strength as you could damage the motherboard.
  9. JBL Flip 6 Charging Port Replacement, Tweeter: 9 단계, 이미지 2개 중 1개 JBL Flip 6 Charging Port Replacement, Tweeter: 9 단계, 이미지 2개 중 2개
    • Remove the two 9.5-mm Philips #1 screws securing the tweeter to the device.
  10. JBL Flip 6 Charging Port Replacement: 10 단계, 이미지 3개 중 1개 JBL Flip 6 Charging Port Replacement: 10 단계, 이미지 3개 중 2개 JBL Flip 6 Charging Port Replacement: 10 단계, 이미지 3개 중 3개
    • Insert an opening pick into the gap along the edge of the tweeter.
    • Push the tip inwards and pry upwards to release the tweeter from the motherboard.
  11. JBL Flip 6 Charging Port Replacement, Charging Port: 11 단계, 이미지 2개 중 1개 JBL Flip 6 Charging Port Replacement, Charging Port: 11 단계, 이미지 2개 중 2개
    • Use a spudger to release the clips attaching the cover for the buttons and charging port.
    • After the two clips are removed, the cover can be removed easier by hand.
  12. JBL Flip 6 Charging Port Replacement: 12 단계, 이미지 2개 중 1개 JBL Flip 6 Charging Port Replacement: 12 단계, 이미지 2개 중 2개
    • After the clips have been released, take the cover off, feeding the strap out of the hole.
  13. JBL Flip 6 Charging Port Replacement: 13 단계, 이미지 3개 중 1개 JBL Flip 6 Charging Port Replacement: 13 단계, 이미지 3개 중 2개 JBL Flip 6 Charging Port Replacement: 13 단계, 이미지 3개 중 3개
    • Remove the two 5.7 mm Philips #00 screws holding the charging port cover in place.
  14. JBL Flip 6 Charging Port Replacement: 14 단계, 이미지 3개 중 1개 JBL Flip 6 Charging Port Replacement: 14 단계, 이미지 3개 중 2개 JBL Flip 6 Charging Port Replacement: 14 단계, 이미지 3개 중 3개
    • Using tweezers, pull the blue ribbon from the connector from the charging port board.
    • After the ribbon is removed, pull the USB-C port out from the outside.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
작성자
4다른 기여자 명과 함께
Banu Seelam
회원 가입일: 09/25/24
205 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 12
지난 7일: 38
지난 30일: 177
전체 시간: 1,441
