주요 콘텐츠로 건너뛰기
JBL Flip 6 Motherboard Replacement
필요한 것
  1. JBL Flip 6 Motherboard Replacement, Case: 1 단계, 이미지 2개 중 1개 JBL Flip 6 Motherboard Replacement, Case: 1 단계, 이미지 2개 중 2개
    • Using the iFixit opening tool, pry up on the button side of the slot on the case until the clips release.
  2. JBL Flip 6 Motherboard Replacement: 2 단계, 이미지 2개 중 1개 JBL Flip 6 Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Now that the gap is larger, using the same tool, pry up on the other side until the clips release.
  3. JBL Flip 6 Motherboard Replacement: 3 단계, 이미지 3개 중 1개 JBL Flip 6 Motherboard Replacement: 3 단계, 이미지 3개 중 2개 JBL Flip 6 Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • With all clips released, slide the case off longways.
    • You may need to spread it a bit with your hands so that the clips do not become caught on the end pieces.
  4. JBL Flip 6 Motherboard Replacement, Tweeter: 4 단계, 이미지 2개 중 1개 JBL Flip 6 Motherboard Replacement, Tweeter: 4 단계, 이미지 2개 중 2개
    • Remove the two 9.5-mm Philips #1 screws securing the tweeter to the device.
  5. JBL Flip 6 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 JBL Flip 6 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 JBL Flip 6 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Insert an opening pick into the gap along the edge of the tweeter.
    • Push the tip inwards and pry upwards to release the tweeter from the motherboard.
  6. JBL Flip 6 Motherboard Replacement, Passive Radiators: 6 단계, 이미지 2개 중 1개 JBL Flip 6 Motherboard Replacement, Passive Radiators: 6 단계, 이미지 2개 중 2개
    • Use a prying tool to lift up on one of the clips that holds the radiator in place.
  7. JBL Flip 6 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 JBL Flip 6 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • After the clip has been released, insert a shim to keep the parts separated and from the clipping back together.
    • Pry on the clip on the other side to fully release the passive radiator.
  8. JBL Flip 6 Motherboard Replacement: 8 단계, 이미지 3개 중 1개 JBL Flip 6 Motherboard Replacement: 8 단계, 이미지 3개 중 2개 JBL Flip 6 Motherboard Replacement: 8 단계, 이미지 3개 중 3개
    • After both clips have been detached, the passive radiator is easier to remove by hand.
    • Repeat the same steps for the passive radiator on the other side.
  9. JBL Flip 6 Motherboard Replacement, Woofer: 9 단계, 이미지 3개 중 1개 JBL Flip 6 Motherboard Replacement, Woofer: 9 단계, 이미지 3개 중 2개 JBL Flip 6 Motherboard Replacement, Woofer: 9 단계, 이미지 3개 중 3개
    • Remove the four 9.5 mm Philips #1 screws securing the woofer to the device.
  10. JBL Flip 6 Motherboard Replacement: 10 단계, 이미지 3개 중 1개 JBL Flip 6 Motherboard Replacement: 10 단계, 이미지 3개 중 2개 JBL Flip 6 Motherboard Replacement: 10 단계, 이미지 3개 중 3개
    • Carefully disconnect the white connector linking the woofer and the motherboard.
    • If there is a lot of resistance when removing the plug, there could be a clip holding it in place. Check for any sort of fasteners before using much strength as you could damage the motherboard.
  11. JBL Flip 6 Motherboard Replacement, Charging Port: 11 단계, 이미지 2개 중 1개 JBL Flip 6 Motherboard Replacement, Charging Port: 11 단계, 이미지 2개 중 2개
    • Use a spudger to release the clips attaching the cover for the buttons and charging port.
    • After the two clips are removed, the cover can be removed easier by hand.
  12. JBL Flip 6 Motherboard Replacement: 12 단계, 이미지 2개 중 1개 JBL Flip 6 Motherboard Replacement: 12 단계, 이미지 2개 중 2개
    • After the clips have been released, take the cover off, feeding the strap out of the hole.
  13. JBL Flip 6 Motherboard Replacement: 13 단계, 이미지 3개 중 1개 JBL Flip 6 Motherboard Replacement: 13 단계, 이미지 3개 중 2개 JBL Flip 6 Motherboard Replacement: 13 단계, 이미지 3개 중 3개
    • Remove the two 5.7 mm Philips #00 screws holding the charging port cover in place.
  14. JBL Flip 6 Motherboard Replacement: 14 단계, 이미지 3개 중 1개 JBL Flip 6 Motherboard Replacement: 14 단계, 이미지 3개 중 2개 JBL Flip 6 Motherboard Replacement: 14 단계, 이미지 3개 중 3개
    • Using tweezers, pull the blue ribbon from the connector from the charging port board.
    • After the ribbon is removed, pull the USB-C port out from the outside.
  15. JBL Flip 6 Motherboard Replacement, Motherboard: 15 단계, 이미지 3개 중 1개 JBL Flip 6 Motherboard Replacement, Motherboard: 15 단계, 이미지 3개 중 2개 JBL Flip 6 Motherboard Replacement, Motherboard: 15 단계, 이미지 3개 중 3개
    • Carefully pull the small ribbon cable from its slot.
    • Lift up on the black locking flaps opposite the ribbon cables, then carefully pull the ribbon cables out of their slots.
  16. JBL Flip 6 Motherboard Replacement: 16 단계, 이미지 2개 중 1개 JBL Flip 6 Motherboard Replacement: 16 단계, 이미지 2개 중 2개
    • Carefully disconnect the small ground connector from the motherboard.
    • When reattaching this connector, it can be tricky to line up and get it to set. The best way to do it is to position the wire with your non-dominant hand, then, using tweezers, pinch the topside of the motherboard and the connector.
  17. JBL Flip 6 Motherboard Replacement: 17 단계, 이미지 3개 중 1개 JBL Flip 6 Motherboard Replacement: 17 단계, 이미지 3개 중 2개 JBL Flip 6 Motherboard Replacement: 17 단계, 이미지 3개 중 3개
    • Remove the two 9.5 mm Philips #1 screws securing the plastic retainer for the battery and motherboard.
  18. JBL Flip 6 Motherboard Replacement: 18 단계, 이미지 2개 중 1개 JBL Flip 6 Motherboard Replacement: 18 단계, 이미지 2개 중 2개
    • Pry up on the black tab, then carefully pull the connector from its port on the motherboard.
  19. JBL Flip 6 Motherboard Replacement: 19 단계, 이미지 3개 중 1개 JBL Flip 6 Motherboard Replacement: 19 단계, 이미지 3개 중 2개 JBL Flip 6 Motherboard Replacement: 19 단계, 이미지 3개 중 3개
    • Push on the inside edge of the motherboard until the battery connector is outside of the device case.
    • Pinch and pull up on the battery connector to release it, freeing both the motherboard and the battery for removal.
  20. JBL Flip 6 Motherboard Replacement: 20 단계, 이미지 3개 중 1개 JBL Flip 6 Motherboard Replacement: 20 단계, 이미지 3개 중 2개 JBL Flip 6 Motherboard Replacement: 20 단계, 이미지 3개 중 3개
    • Pull out both the battery and motherboard, and repair or replace as needed.
결론
작성자
2다른 기여자 명과 함께
Cody Chamberlain
회원 가입일: 09/25/24
414 평판
안내서 3개를 작성함
1가이드 댓글
Where do I find parts specifically the white ribbon that leads to control buttons and the control board.
Sketch Mastertask - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 19
지난 30일: 142
전체 시간: 1,525
