주요 콘텐츠로 건너뛰기
JBL Flip 6 Passive Radiators Replacement
필요한 것
  1. JBL Flip 6 Passive Radiators Replacement, Case: 1 단계, 이미지 2개 중 1개 JBL Flip 6 Passive Radiators Replacement, Case: 1 단계, 이미지 2개 중 2개
    • Using the iFixit opening tool, pry up on the button side of the slot on the case until the clips release.
  2. JBL Flip 6 Passive Radiators Replacement: 2 단계, 이미지 2개 중 1개 JBL Flip 6 Passive Radiators Replacement: 2 단계, 이미지 2개 중 2개
    • Now that the gap is larger, using the same tool, pry up on the other side until the clips release.
  3. JBL Flip 6 Passive Radiators Replacement: 3 단계, 이미지 3개 중 1개 JBL Flip 6 Passive Radiators Replacement: 3 단계, 이미지 3개 중 2개 JBL Flip 6 Passive Radiators Replacement: 3 단계, 이미지 3개 중 3개
    • With all clips released, slide the case off longways.
    • You may need to spread it a bit with your hands so that the clips do not become caught on the end pieces.
  4. JBL Flip 6 Passive Radiators Replacement, Passive Radiators: 4 단계, 이미지 2개 중 1개 JBL Flip 6 Passive Radiators Replacement, Passive Radiators: 4 단계, 이미지 2개 중 2개
    • Use a prying tool to lift up on one of the clips that holds the radiator in place.
  5. JBL Flip 6 Passive Radiators Replacement: 5 단계, 이미지 2개 중 1개 JBL Flip 6 Passive Radiators Replacement: 5 단계, 이미지 2개 중 2개
    • After the clip has been released, insert a shim to keep the parts separated and from the clipping back together.
    • Pry on the clip on the other side to fully release the passive radiator.
  6. JBL Flip 6 Passive Radiators Replacement: 6 단계, 이미지 3개 중 1개 JBL Flip 6 Passive Radiators Replacement: 6 단계, 이미지 3개 중 2개 JBL Flip 6 Passive Radiators Replacement: 6 단계, 이미지 3개 중 3개
    • After both clips have been detached, the passive radiator is easier to remove by hand.
    • Repeat the same steps for the passive radiator on the other side.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
작성자
2다른 기여자 명과 함께
Banu Seelam
회원 가입일: 09/25/24
205 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 25
지난 30일: 85
전체 시간: 875
