주요 콘텐츠로 건너뛰기
JBL Flip disassembly
필요한 것
  1. JBL Flip disassembly, JBL Flip disassembly: 1 단계, 이미지 1/3 JBL Flip disassembly, JBL Flip disassembly: 1 단계, 이미지 2/3 JBL Flip disassembly, JBL Flip disassembly: 1 단계, 이미지 3/3
    • On the end with the buttons, remove the end cap using the flat head screwdriver to get between the rubber lining and the plastic.
    • After the cap is removed, unscrew the two 3.3mm screws using a size 1 ph screw driver.
  2. JBL Flip disassembly: 2 단계, 이미지 1/3 JBL Flip disassembly: 2 단계, 이미지 2/3 JBL Flip disassembly: 2 단계, 이미지 3/3
    • Unscrew four 3.3mm screws on each end of the JBL using a size 1 ph screw driver (8 screws total).
  3. JBL Flip disassembly: 3 단계, 이미지 1/3 JBL Flip disassembly: 3 단계, 이미지 2/3 JBL Flip disassembly: 3 단계, 이미지 3/3
    • Remove outermost white casing by gently lifting up on one side.
    • Remove two 5mm screws holding the silver back plate in place with a size 2 ph screw driver.
    • Gently lift up and remove the silver casing.
  4. JBL Flip disassembly: 4 단계, 이미지 1/1
    • Remove last white back plate to expose the back of the speaker cover.
  5. JBL Flip disassembly: 5 단계, 이미지 1/3 JBL Flip disassembly: 5 단계, 이미지 2/3 JBL Flip disassembly: 5 단계, 이미지 3/3
    • Pry the four tabs on each side of the speaker cover (8 tabs total).
    • Pry the two tabs on each end to remove the cover (4 tabs total).
    • Slide speaker out of metal speaker cover.
  6. JBL Flip disassembly: 6 단계, 이미지 1/3 JBL Flip disassembly: 6 단계, 이미지 2/3 JBL Flip disassembly: 6 단계, 이미지 3/3
    • Remove 5mm screw in the middle of the back of the device with a size 2 ph screw driver.
    • Unscrew the two 5mm screws on each side using a size 2 ph screwdriver.
    • Open the speaker.
결론
다른 12명이 해당 안내서를 완성하였습니다.
Dillon
회원 가입일: 03/11/15
1,556 평판
안내서 5개 작성하였습니다
Colorado Springs, Team 9-5, Panko Spring 2015 Colorado Springs, Team 9-5, Panko Spring 2015 회원
UCCS-PANKO-S15S9G5
3 회원들
안내서 5개 작성하였습니다
댓글 4개
How do i take apart jbl flip 3
Ricky Tomas - 답글
My jbl flip 3 Bluetooth button does not function.How do I fix the problem?
Francis
fwathika - 답글
The charging PCB on my Flip3 is damaged and needs to be replaced. Any chance of purchasing the charging/interface module, fully populated?
I live in South Africa, and cannot find it here!
Paul M
Paul Moulang - 답글
The charging PCB on my JBL Flip3 is also damaged and needs to be replaced. Any chance of purchasing the charging/interface module?
I live in Pune - Maharashtra in India and cannot find a good reliable service station for JBL speakers here!
Suresh Karve
Suresh Karve - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 11
30일 전: 44
전체 시간: 21,965
