주요 콘텐츠로 건너뛰기
JBL Go 3 Battery Replacement
필요한 것
  1. JBL Go 3 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 JBL Go 3 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Use a Jimmy or opening pick to gently lift one corner of the fabric mesh, then carefully remove the entire fabric and shell.
    • Insert the Jimmy along the seam and gently pry open the housing.
    • Work your way around the speaker, unclipping the internal latches as you go.
  2. JBL Go 3 Battery Replacement: 2 단계, 이미지 3개 중 1개 JBL Go 3 Battery Replacement: 2 단계, 이미지 3개 중 2개 JBL Go 3 Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Around the rubber circle, you’ll find four small screws.
    • Use a screwdriver to remove the screws.
    • Then gently use a Jimmy to open the speaker’s housing.
  3. JBL Go 3 Battery Replacement: 3 단계, 이미지 3개 중 1개 JBL Go 3 Battery Replacement: 3 단계, 이미지 3개 중 2개 JBL Go 3 Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Unscrew the motherboard to access the battery.
    • Locate the battery, it’s usually wrapped in black or silver and connected to the mainboard by a small cable.
    • Carefully disconnect the battery connector from the circuit board.
    • Remove the old battery, replace it with the new one and reconnect the cable securely.
    • Close the housing, screw everything back in place, and reattach the fabric mesh.
결론
작성자
3다른 기여자 명과 함께
Kasey Oliver
회원 가입일: 03/18/25
507 평판
안내서 5개를 작성함
UMass Dartmouth, Team 4-5, Konn Spring 2025 UMass Dartmouth, Team 4-5, Konn Spring 2025 회원
UMASSD-KONN-S25S4G5
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 42
전체 시간: 340
