주요 콘텐츠로 건너뛰기
JBL Go 3 Driver Replacement
필요한 것
  1. JBL Go 3 Driver Replacement, Driver: 1 단계, 이미지 2개 중 1개 JBL Go 3 Driver Replacement, Driver: 1 단계, 이미지 2개 중 2개
    • Hold the power button until the JBL Go 3 shuts off
    • Disconnect any charging cables
    • Use jimmy to remove the hard shell
    • Work your way around the edges slowly—be patient as it's glued or snapped in tightly
  2. JBL Go 3 Driver Replacement: 2 단계, 이미지 3개 중 1개 JBL Go 3 Driver Replacement: 2 단계, 이미지 3개 중 2개 JBL Go 3 Driver Replacement: 2 단계, 이미지 3개 중 3개
    • Once the hard shell is removed,use jimmy to lift up the speaker part.
    • Locate the internal screws underneath the outer shell.
    • Use your precision screwdriver to remove all screws securing the plastic enclosure.
    • Carefully lift the casing to expose the speaker and other internal components.
  3. JBL Go 3 Driver Replacement: 3 단계, 이미지 2개 중 1개 JBL Go 3 Driver Replacement: 3 단계, 이미지 2개 중 2개
    • If accessible, unplug the battery to prevent any electrical short while working.
    • If it's soldered, proceed carefully and avoid touching metal contacts unnecessarily.
    • Unscrew any fasteners holding the speaker in place.
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
작성자
1다른 기여자 명과 함께
Kasey Oliver
회원 가입일: 03/18/25
507 평판
안내서 5개를 작성함
UMass Dartmouth, Team 4-5, Konn Spring 2025 UMass Dartmouth, Team 4-5, Konn Spring 2025 회원
UMASSD-KONN-S25S4G5
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 29
전체 시간: 323
