주요 콘텐츠로 건너뛰기
JBL Go 3 Motherboard Replacement
필요한 것
  1. JBL Go 3 Motherboard Replacement, Grille: 1 단계, 이미지 3개 중 1개 JBL Go 3 Motherboard Replacement, Grille: 1 단계, 이미지 3개 중 2개 JBL Go 3 Motherboard Replacement, Grille: 1 단계, 이미지 3개 중 3개
    • Using an iFixit Opening Pick or a Jimmy, pry along the seam between the rubber outer layer and the hard shell.
    • Work your way around the edges until the shell loosens and can be fully removed.
  2. JBL Go 3 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 JBL Go 3 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 JBL Go 3 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Once the shell is loosened on all sides, gently lift and remove it completely.
    • Align the new shell with the speaker’s body, making sure all edges are properly positioned.
    • Press firmly around the edges until the shell snaps securely into place.
  3. JBL Go 3 Motherboard Replacement, Motherboard: 3 단계, 이미지 2개 중 1개 JBL Go 3 Motherboard Replacement, Motherboard: 3 단계, 이미지 2개 중 2개
    • Locate the internal screws underneath the outer shell.
    • Use your precision screwdriver to remove all screws securing the plastic enclosure.
    • Carefully lift the casing to expose the motherboard and other internal components.
  4. JBL Go 3 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 JBL Go 3 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Unscrew the motherboard to the internal casing of the speaker.
    • Unscrew the speaker attached to the casing as well.
    • The speaker and part of the battery may be soldered onto the motherboard, proceed with caution when removing attachments
결론
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
작성자
1다른 기여자 명과 함께
Kasey Oliver
회원 가입일: 03/18/25
507 평판
안내서 5개를 작성함
UMass Dartmouth, Team 4-5, Konn Spring 2025 UMass Dartmouth, Team 4-5, Konn Spring 2025 회원
UMASSD-KONN-S25S4G5
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 32
전체 시간: 164
