소개
Use this guide to replace a damaged front cover of your JBL Go.
The outer front cover protects the rest of the parts of your speaker. If it becomes damaged, then the other parts could become damaged, as well. This could also affect the audio quality of your speaker.
Steps 1 and 2 require the use of an opening tool to scrape away the glue that holds the front cover in place. This glue is strong, so be careful as you scrape because you could cut yourself with the opening tool.
필요한 것
Use an opening tool to scrape around the outside of the front cover to remove the glue attaching it to the surrounding rubber layer.
다른 2명이 해당 안내서를 완성하였습니다.
