주요 콘텐츠로 건너뛰기
JBL Go Repair Motherboard Replacement
필요한 것
  1. JBL Go Repair Motherboard Replacement, Front Cover: 1 단계, 이미지 1개 중 1개
    • Use an opening tool to scrape around the outside of the front cover to remove the glue attaching it to the surrounding rubber layer.
  2. JBL Go Repair Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Once you have scraped off all of the glue, use the opening tool to pry up the front cover.
  3. JBL Go Repair Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully remove the loose plastic cover from the speaker.
  4. JBL Go Repair Motherboard Replacement, Motherboard: 4 단계, 이미지 1개 중 1개
    • Once the front cover is removed, use a T6 screwdriver to remove the four 9 mm screws on the black cover.
  5. JBL Go Repair Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • After removing the screws, use the plastic opening tool to carefully pry around the edges of the black cover to loosen and lift the cover off of the device.
  6. JBL Go Repair Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Carefully unplug the woofer wires from the motherboard.
  7. JBL Go Repair Motherboard Replacement: 7 단계, 이미지 1개 중 1개
    • Use the T6 screwdriver to remove the 9 mm screw that secures the motherboard in place.
  8. JBL Go Repair Motherboard Replacement: 8 단계, 이미지 1개 중 1개
    • Lift the motherboard using the plastic opening tool and stick it through the hole in the middle of the board.
  9. JBL Go Repair Motherboard Replacement: 9 단계, 이미지 1개 중 1개
    • Carefully lift the motherboard, sliding the charging port side out of the frame of the speaker as you go.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Sydney Jason
회원 가입일: 03/21/22
824 평판
안내서 4개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 17
지난 30일: 138
전체 시간: 5,489
