주요 콘텐츠로 건너뛰기
JBL L26 Speaker Replacement
필요한 것
  1. JBL L26 Speaker Replacement, Speaker: 1 단계, 이미지 1/1
    • Remove the four 6.4 mm Phillips #2 screws from the front of the speaker.
  2. JBL L26 Speaker Replacement: 2 단계, 이미지 1/1
    • Pull the speaker out of the frame and lay it onto the side.
  3. JBL L26 Speaker Replacement: 3 단계, 이미지 1/1
    • Unlatch the green wire by pulling on the terminal connector and not the wire.
  4. JBL L26 Speaker Replacement: 4 단계, 이미지 1/2 JBL L26 Speaker Replacement: 4 단계, 이미지 2/2
    • Use a small prying tool to pry the terminal connector off of the tap.
    • After you unlatched both edges, pull the black wire out.
  5. JBL L26 Speaker Replacement: 5 단계, 이미지 1/1
    • Get your replacement speaker and connect the green wire by pushing the terminal connector onto the tap.
  6. JBL L26 Speaker Replacement: 6 단계, 이미지 1/2 JBL L26 Speaker Replacement: 6 단계, 이미지 2/2
    • Connect the black wire by attaching the terminal connector onto the tap.
    • Use a clamping tool to clip the edges toward the tap.
    • Be careful not to clamp too hard so you don't damage the tap.
  7. JBL L26 Speaker Replacement: 7 단계, 이미지 1/1
    • Place the new speaker onto the frame and screw the four 6.4 mm Phillips #2 screws back in.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Nathnael Dubale
회원 가입일: 09/20/20
269 평판
안내서 1개 작성함
York University, Team S2-G45, Melo-Thaiss Fall 2020 York University, Team S2-G45, Melo-Thaiss Fall 2020 회원
YORK-MELO-THAISS-F20S2G45
1 회원
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 21
전체 시간: 1,034
