소개
This guide provides the steps necessary in order to replace the thirty-pin connector.
필요한 것
Turn the device upside down so that the three rubber pads are facing up.
Apply heat with a heatgun on a low setting to the area around the 30-pin connector until you can easily pry it out by the seam surrounding it (about 10 minutes).
다른 한 분이 해당 안내서를 완성하였습니다.
댓글 2개
and how you get a new one of the 30 pin connector?
