주요 콘텐츠로 건너뛰기
JBL On Stage II 30-Pin Connector Replacement
필요한 것
  1. JBL On Stage II 30-Pin Connector Replacement, Cracking the Case: 1 단계, 이미지 1/1
    • Turn the device upside down so that the three rubber pads are facing up.
  2. JBL On Stage II 30-Pin Connector Replacement: 2 단계, 이미지 1/1
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. JBL On Stage II 30-Pin Connector Replacement: 3 단계, 이미지 1/1
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. JBL On Stage II 30-Pin Connector Replacement: 4 단계, 이미지 1/2 JBL On Stage II 30-Pin Connector Replacement: 4 단계, 이미지 2/2
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. JBL On Stage II 30-Pin Connector Replacement: 5 단계, 이미지 1/3 JBL On Stage II 30-Pin Connector Replacement: 5 단계, 이미지 2/3 JBL On Stage II 30-Pin Connector Replacement: 5 단계, 이미지 3/3
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. JBL On Stage II 30-Pin Connector Replacement: 6 단계, 이미지 1/1
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  7. JBL On Stage II 30-Pin Connector Replacement: 7 단계, 이미지 1/2 JBL On Stage II 30-Pin Connector Replacement: 7 단계, 이미지 2/2
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
  8. JBL On Stage II 30-Pin Connector Replacement, 30-Pin Connector Replacement: 8 단계, 이미지 1/1
    • Apply heat with a heatgun on a low setting to the area around the 30-pin connector until you can easily pry it out by the seam surrounding it (about 10 minutes).
  9. JBL On Stage II 30-Pin Connector Replacement: 9 단계, 이미지 1/1
    • Use a metal spudger to pry out the plastic surrounding the 30-pin connector.
  10. JBL On Stage II 30-Pin Connector Replacement: 10 단계, 이미지 1/1
    • Use a pair of tweezers to wiggle out the 30-pin connector.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Janessa D Cabrera
회원 가입일: 01/23/14
514 평판
안내서 4개 작성하였습니다
Cal Poly, Team 9-28, Maness Winter 2014 Cal Poly, Team 9-28, Maness Winter 2014 회원
CPSU-MANESS-W14S9G28
4 회원들
안내서 7개 작성하였습니다
댓글 2개
and how you get a new one of the 30 pin connector?
bini barazany - 답글
Yes, where can we buy a new one of the 30 pin connector?
Jimbo - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 4,428
