이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
To complete this guide, you will need to disassemble your device and use a soldering iron to replace the jack.
필요한 것
Turn the device upside down so that the three rubber pads are facing up.
Turn the device upside down.
Desolder the back lead for the auxiliary port that is circled.
Heat the lead until the solder melts.
Remove the solder with the solder pump.
For help with soldering view the iFixit soldering guide
To reassemble your device, replace the auxiliary jack with a new one soldering it in place. Follow these instructions in reverse order.
다른 한 분이 해당 안내서를 완성하였습니다.
