Introduction
This guide shows you how to replace the spring on the power button.
  1. Turn the device upside down so that the three rubber pads are facing up.
    • Turn the device upside down so that the three rubber pads are facing up.
  2. Use a heat gun (set to low) to apply heat  to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
    • Pull the plastic button off the post.
    • Remove the metal U-clip (compressing the spring) with tweezers.
Janessa D Cabrera
478 Reputation
4 Guides authored
Cal Poly, Team 9-28, Maness Winter 2014 Member of Cal Poly, Team 9-28, Maness Winter 2014
CPSU-MANESS-W14S9G28
4 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 1,367
