주요 콘텐츠로 건너뛰기
JBL On Stage II Power Jack Replacement
필요한 것
  1. JBL On Stage II Power Jack Replacement, Cracking the Case: 1 단계, 이미지 1/1
    • Turn the device upside down so that the three rubber pads are facing up.
  2. JBL On Stage II Power Jack Replacement: 2 단계, 이미지 1/1
    • Use a heat gun (set to low) to apply heat to one of the rubber pads until you can easily remove the pad. This step takes around 5-7 minutes.
  3. JBL On Stage II Power Jack Replacement: 3 단계, 이미지 1/1
    • Remove the heated rubber pad with a plastic opening tool.
    • Repeat steps 2 and 3 for the two remaining rubber pads.
  4. JBL On Stage II Power Jack Replacement: 4 단계, 이미지 1/2 JBL On Stage II Power Jack Replacement: 4 단계, 이미지 2/2
    • Remove the six 1cm T-10 torx screws on the bottom of the device (found under the rubber pads) using a T-10 Torx screwdriver.
  5. JBL On Stage II Power Jack Replacement: 5 단계, 이미지 1/3 JBL On Stage II Power Jack Replacement: 5 단계, 이미지 2/3 JBL On Stage II Power Jack Replacement: 5 단계, 이미지 3/3
    • Open the device along its seam.
    • Be careful when separating the device because there are wires connecting the two seperate halves.
  6. JBL On Stage II Power Jack Replacement: 6 단계, 이미지 1/1
    • Disconnect the ribbon cable connector from the top half of the device by pulling outward and parallel to the connecting pins.
  7. JBL On Stage II Power Jack Replacement: 7 단계, 이미지 1/2 JBL On Stage II Power Jack Replacement: 7 단계, 이미지 2/2
    • Locate and disconnect the two molex connectors found on either side of the ribbon cable connector on the bottom half of the device.
    Where do I find these speakers
    HighChief - 답글
  8. JBL On Stage II Power Jack Replacement, Circuit Board: 8 단계, 이미지 1/2 JBL On Stage II Power Jack Replacement, Circuit Board: 8 단계, 이미지 2/2
    • Remove the three 1 cm T-10 Torx screws.
  9. JBL On Stage II Power Jack Replacement: 9 단계, 이미지 1/1
    • Carefully press out the white base tube and push up on the circuit board.
    • Note that there is a small wire connecting the circuit board to the base.
  10. JBL On Stage II Power Jack Replacement: 10 단계, 이미지 1/2 JBL On Stage II Power Jack Replacement: 10 단계, 이미지 2/2
    • Pull the white wire out of the hot glue.
  11. JBL On Stage II Power Jack Replacement: 11 단계, 이미지 1/3 JBL On Stage II Power Jack Replacement: 11 단계, 이미지 2/3 JBL On Stage II Power Jack Replacement: 11 단계, 이미지 3/3
    • Unbolt the heatsink with a 5.5-mm socket and a Phillips PH1 screwdriver.
    • Remove the heat sink; it should detach from the bottom of the device.
  12. JBL On Stage II Power Jack Replacement: 12 단계, 이미지 1/3 JBL On Stage II Power Jack Replacement: 12 단계, 이미지 2/3 JBL On Stage II Power Jack Replacement: 12 단계, 이미지 3/3
    • Remove the T-10 torx screw on the bottom of the device that attaches the base tube to the circuit board.
    • Turn the device so that the base tube is on top.
    • Remove the base tube by pulling up.
    • May need to cut the rubber adhesive between the base tube to the circuit board.
  13. JBL On Stage II Power Jack Replacement, Power Jack: 13 단계, 이미지 1/3 JBL On Stage II Power Jack Replacement, Power Jack: 13 단계, 이미지 2/3 JBL On Stage II Power Jack Replacement, Power Jack: 13 단계, 이미지 3/3
    이 단계에 사용된 도구:
    Desoldering Pump
    $3.99
    구매
    • Turn the device upside down.
    • Solder the back lead of the power jack until the solder melts.
    • Heat the lead until the solder melts.
    • Remove the solder with the desoldering pump.
    • For help with soldering view the iFixit soldering guide
  14. JBL On Stage II Power Jack Replacement: 14 단계, 이미지 1/1
    • Repeat step 13 for the other two leads
  15. JBL On Stage II Power Jack Replacement: 15 단계, 이미지 1/1
    • Remove the power jack.
결론
Replace the power jack with the new jack and resolder the leads. Follow the steps in reverse order to reassemble your device
Jared Everingham
회원 가입일: 01/23/14
368 평판
안내서 3개 작성하였습니다
Cal Poly, Team 9-28, Maness Winter 2014 Cal Poly, Team 9-28, Maness Winter 2014 회원
CPSU-MANESS-W14S9G28
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
Do you know where to find a sound jack for my JBL On Stage? Thanks
David Díaz - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 1
전체 시간: 1,118
