소개
If your JBL 2 speaker isn't working correctly or delivering the high-quality sounds you expect, you may need to replace the battery. Replacing the battery can breathe new life into your device.
필요한 것
Remove the rubber rings from either end of the device.
If there is difficulty in lifting the rings from the device, use the metal spudger.
거의 끝나갑니다!
결론
다른 6명이 해당 안내서를 완성하였습니다.
