주요 콘텐츠로 건너뛰기
JBL Pulse 2 Battery Replacement
필요한 것
  1. JBL Pulse 2 Battery Replacement, Battery: 1 단계, 이미지 2개 중 1개 JBL Pulse 2 Battery Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the rubber rings from either end of the device.
    • If there is difficulty in lifting the rings from the device, use the metal spudger.
  2. JBL Pulse 2 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four 4.8mm Phillips #1 screws from each end of the device with the Phillips head screwdriver.
    • Lift the end pieces off of the device.
  3. JBL Pulse 2 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the four 9.5mm Phillips #1 screws from each end of the device.
  4. JBL Pulse 2 Battery Replacement: 4 단계, 이미지 2개 중 1개 JBL Pulse 2 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Peel one end off and slowly draw it across the length of the device until you get to the other side.
  5. JBL Pulse 2 Battery Replacement: 5 단계, 이미지 3개 중 1개 JBL Pulse 2 Battery Replacement: 5 단계, 이미지 3개 중 2개 JBL Pulse 2 Battery Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the four 7.9mm Phillips #1 screws along the black centerpiece of the device between the camera and the auxiliary port.
    • Lift up the casing and circuit board but do not try and remove the ribbon wires.
  6. JBL Pulse 2 Battery Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the cover from the end that the ribbon wires are attached to. It should peel off easily.
  7. JBL Pulse 2 Battery Replacement: 7 단계, 이미지 2개 중 1개 JBL Pulse 2 Battery Replacement: 7 단계, 이미지 2개 중 2개
    • Unlatch the mechanism holding the ribbon wires in place, then disconnect them from the motherboard.
    • To access the wires, remove some of the black glue holding them in place with the spudger.
  8. JBL Pulse 2 Battery Replacement: 8 단계, 이미지 2개 중 1개 JBL Pulse 2 Battery Replacement: 8 단계, 이미지 2개 중 2개
    • Slowly pull the ribbon wires out from the outside.
    • If there is too much resistance, remove more of the black glue.
  9. JBL Pulse 2 Battery Replacement: 9 단계, 이미지 2개 중 1개 JBL Pulse 2 Battery Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the four 7.9mm Phillips #1 screws around the edges of the center piece.
    • Slide the outer casing off away from the auxiliary and micro USB port.
  10. JBL Pulse 2 Battery Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the other end of the device to access the wiring underneath it.
  11. JBL Pulse 2 Battery Replacement: 11 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $3.99
    • Use the angled tweezers to disconnect the battery from the motherboard. It will take some work to remove this piece.
  12. JBL Pulse 2 Battery Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the four 7.9mm Phillips #1 screws from the black centerpiece of the device.
  13. JBL Pulse 2 Battery Replacement: 13 단계, 이미지 2개 중 1개 JBL Pulse 2 Battery Replacement: 13 단계, 이미지 2개 중 2개
    • Use the spudger to reach under the sides of the black centerpiece to access the six latches, three of which are on each side.
  14. JBL Pulse 2 Battery Replacement: 14 단계, 이미지 2개 중 1개 JBL Pulse 2 Battery Replacement: 14 단계, 이미지 2개 중 2개
    • Lift the black centerpiece off with the metal spudger to reveal the battery underneath.
  15. JBL Pulse 2 Battery Replacement: 15 단계, 이미지 1개 중 1개
    • Use a hot air gun to soften the hot glue in order to fully remove the battery.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jarid Slopek
회원 가입일: 08/31/18
457 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 76
전체 시간: 9,513
