주요 콘텐츠로 건너뛰기
JBL Pulse 2 Motherboard Replacement
필요한 것
  1. JBL Pulse 2 Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 1개 JBL Pulse 2 Motherboard Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Remove the rubber rings from either end of the device.
    • If there is difficulty in lifting the rings from the device, use the metal spudger.
  2. JBL Pulse 2 Motherboard Replacement: 2 단계, 이미지 1개 중 1개
    • Remove the four 4.8mm Phillips #1 screws from each end of the device with the Phillips head screwdriver.
    • Lift the end pieces off of the device.
  3. JBL Pulse 2 Motherboard Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the four 9.5mm Phillips #1 screws from each end of the device.
  4. JBL Pulse 2 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 JBL Pulse 2 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Peel one end off and slowly draw it across the length of the device until you get to the other side.
  5. JBL Pulse 2 Motherboard Replacement: 5 단계, 이미지 3개 중 1개 JBL Pulse 2 Motherboard Replacement: 5 단계, 이미지 3개 중 2개 JBL Pulse 2 Motherboard Replacement: 5 단계, 이미지 3개 중 3개
    • Remove the four 7.9mm Phillips #1 screws along the black centerpiece of the device between the camera and the auxiliary port.
    • Lift up the casing and circuit board but do not try and remove the ribbon wires.
  6. JBL Pulse 2 Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the cover from the end that the ribbon wires are attached to. It should peel off easily.
  7. JBL Pulse 2 Motherboard Replacement: 7 단계, 이미지 2개 중 1개 JBL Pulse 2 Motherboard Replacement: 7 단계, 이미지 2개 중 2개
    • Unlatch the mechanism holding the ribbon wires in place, then disconnect them from the motherboard.
    • To access the wires, remove some of the black glue holding them in place with the spudger.
  8. JBL Pulse 2 Motherboard Replacement: 8 단계, 이미지 2개 중 1개 JBL Pulse 2 Motherboard Replacement: 8 단계, 이미지 2개 중 2개
    • Slowly pull the ribbon wires out from the outside.
    • If there is too much resistance, remove more of the black glue.
  9. JBL Pulse 2 Motherboard Replacement: 9 단계, 이미지 2개 중 1개 JBL Pulse 2 Motherboard Replacement: 9 단계, 이미지 2개 중 2개
    • Remove the four 7.9mm Phillips #1 screws around the edges of the center piece.
    • Slide the outer casing off away from the auxiliary and micro USB port.
  10. JBL Pulse 2 Motherboard Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the other end of the device to access the wiring underneath it.
  11. JBL Pulse 2 Motherboard Replacement: 11 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    $3.99
    • Use the angled tweezers to disconnect the battery from the motherboard. It will take some work to remove this piece.
  12. JBL Pulse 2 Motherboard Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the four 7.9mm Phillips #1 screws from the black centerpiece of the device.
  13. JBL Pulse 2 Motherboard Replacement: 13 단계, 이미지 2개 중 1개 JBL Pulse 2 Motherboard Replacement: 13 단계, 이미지 2개 중 2개
    • Use the spudger to reach under the sides of the black centerpiece to access the six latches, three of which are on each side.
  14. JBL Pulse 2 Motherboard Replacement: 14 단계, 이미지 2개 중 1개 JBL Pulse 2 Motherboard Replacement: 14 단계, 이미지 2개 중 2개
    • Lift the black centerpiece off with the metal spudger to reveal the battery underneath.
  15. JBL Pulse 2 Motherboard Replacement: 15 단계, 이미지 1개 중 1개
    • Use a hot air gun to soften the hot glue in order to fully remove the battery.
  16. JBL Pulse 2 Motherboard Replacement, Motherboard: 16 단계, 이미지 3개 중 1개 JBL Pulse 2 Motherboard Replacement, Motherboard: 16 단계, 이미지 3개 중 2개 JBL Pulse 2 Motherboard Replacement, Motherboard: 16 단계, 이미지 3개 중 3개
    • Manually remove the LED strips from the outside of the white plastic casing.
  17. JBL Pulse 2 Motherboard Replacement: 17 단계, 이미지 3개 중 1개 JBL Pulse 2 Motherboard Replacement: 17 단계, 이미지 3개 중 2개 JBL Pulse 2 Motherboard Replacement: 17 단계, 이미지 3개 중 3개
    • Use the Phillips #1 screwdriver to remove the ten 9.5mm screws that hold the cage in place.
    • Lift the cage off.
  18. JBL Pulse 2 Motherboard Replacement: 18 단계, 이미지 2개 중 1개 JBL Pulse 2 Motherboard Replacement: 18 단계, 이미지 2개 중 2개
    • Use the Phillips #1 screwdriver to remove the eight 6.4mm screws that hold the speakers in place.
    • Partially remove the speakers so you can see where they connect to the motherboard.
  19. JBL Pulse 2 Motherboard Replacement: 19 단계, 이미지 2개 중 1개 JBL Pulse 2 Motherboard Replacement: 19 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the straight tweezers to disconnect the speakers from the motherboard.
    • Fully remove the speakers once they are disconnected from the motherboard.
  20. JBL Pulse 2 Motherboard Replacement: 20 단계, 이미지 1개 중 1개
    • Disconnect the remaining wires from the motherboard with the straight tweezers.
    • Be cautious when performing this step. The mic wire is fragile and liable to break.
  21. JBL Pulse 2 Motherboard Replacement: 21 단계, 이미지 1개 중 1개
    • Use a hot air gun to soften the glue from the corners of the motherboard.
    • Slide the motherboard out of the casing.
    • The hot glue covers portions of the motherboard so be careful when softening and removing it.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Emilee Hicks
회원 가입일: 08/31/18
833 평판
안내서 3개를 작성함
1가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 42
전체 시간: 2,662
